exhaust piping under the gas tank
Old Aug 10, 2004 | 11:40 AM
urquidezj's Avatar
Default exhaust piping under the gas tank
ok, i am gonna do this this weekend so i need to know before i do it. i have seen many people in this site put the exhaust piping under the tank. i like how the muffler come out at an angle you cant get if you follow the stock path. so what i wanted to know is if this was safe. i am taking votes to see if i should do it or not,i dont want to blow if when i hit a bump and it causes a spark on the gas tank.
Old Aug 10, 2004 | 01:16 PM
13sechatch's Avatar
mine is ran that way safe yes ground clearance not much. ill try to take pics and post them up for you .
Old Aug 10, 2004 | 02:02 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (13sechatch)
Yeah, its safe.. Pipe doesn't get that hot.
Old Aug 10, 2004 | 02:21 PM
urquidezj's Avatar
Default Re: (LSVTEC 91 Civic)
post me some pics so i can more or less have an idea how ro have it done. whatr i was thinking is right before it gets to the gass tanks put a flange for removal when my fuel pump messes up or need to remove gas tank what do you all think?
Old Aug 10, 2004 | 03:23 PM
Fobtions's Avatar
Default Re: (urquidezj)
be careful cause the clearance is really gonna suck and your tank itself will get banged up by the piping.
cars that have this style exhaust look totally different underneath than our EF's .
Old Aug 10, 2004 | 03:41 PM
Lo-Buck EF's Avatar
Default Re: (Fobtions)
why not come out the back crooked to the left? plenty of room to do that
Old Aug 10, 2004 | 03:46 PM
urquidezj's Avatar
Default Re: (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">be careful cause the clearance is really gonna suck and your tank itself will get banged up by the piping.
cars that have this style exhaust look totally different underneath than our EF's . </TD></TR></TABLE>
well my car is lowered 2 inches, i can fit a finger in every wheel well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">why not come out the back crooked to the left? plenty of room to do that</TD></TR></TABLE>
also thinking about that, i just want to ask if it is safe and will count how many nos and hw many yes i get i got till saturday to decide anyways.
thanks
anybody else?
Old Aug 10, 2004 | 06:26 PM
urquidezj's Avatar
bump
Old Aug 10, 2004 | 09:41 PM
urquidezj's Avatar
thats 2 yes and 2 no, i cant make my decicion like this. please help!!
Old Aug 10, 2004 | 09:49 PM
4DRmafia's Avatar
i wouldnt do it, i am shittin scared if idid that and afraid that the gas tank would blow to ****
Old Aug 10, 2004 | 10:15 PM
urquidezj's Avatar
Default Re: (SkipMic2006)
3 no 2 yes
Old Aug 10, 2004 | 10:23 PM
HondaKPX's Avatar
i wouldnt. you would smash that thing so fast. just run it along the stock path and then left and then crooked. thats how i have it. works fine. no clearence problems.
Old Aug 10, 2004 | 10:35 PM
4DRmafia's Avatar
same thing with mines
Old Aug 10, 2004 | 10:41 PM
hondacivic4g's Avatar
Default Re: exhaust piping under the gas tank (urquidezj)
I have a custom 2.25" exhaust that runs straight under the gas tank. I have a 2" drop F&R ( Progress Group springs). My ehaust has 3 inches(at lowest point right at the gas tank) of clearance for now. Yea it scrapes, due to the fact that the stock shocks are blown. Mostly scrapes when I hit bad bumps(no dampening) and high speed bumps or grades in the road. But i still love my exhaust, only has 1 mandrel bend at 45 degrees from the header, angling it to the drivers side in the original exhaust hole in the bumper.I'm getting Neuspeed Koni's because they have adjustable perches allowing me to raise the car front and or rear either 1/3 inch or little over 1/2 inch (.60 inch). Fronts fine ,just want to raise the rear up for clearance issues. Hope that helps. Here are pics-
Later-Jason
Old Aug 10, 2004 | 10:46 PM
4DRmafia's Avatar
i still wont do it
Old Aug 10, 2004 | 11:16 PM
If it matters i've had mine for 7 monthes and still thereare no major problems (just what was mentioned above). But i had and have no problem w/ taking the chance. I wanted the best over all function, and i got it while I had the DPFI set up in my 1.5L set up w/ the 4spd. i gained power in all my gears. It was weird and refreshing, i wasn't a speed demon, but still excelerated through all the gears even 4th , including up hills. The ability to have power in any gear , including up hill was and is awesome and is still there. So it is and was, one of the greatest investments i've made. I can't account for durability, but I can speak on the behalf of function.
Jason
Old Aug 11, 2004 | 12:20 AM
hahagasdcrx's Avatar
Default Re: (hondacivic4g)
mine works with no problems even on these shitty Mississippi roads
Old Aug 11, 2004 | 03:43 AM
Garrett's Avatar
Default Re: (hahagasdcrx)
IU don't like the piping from hondacivic4g, if you place the piping in the middle it will hit the ground more often.
Mine is the the left, look here
Old Aug 11, 2004 | 05:48 AM
manson's Avatar
Default Re: (Garrett)
why not put it on right and then have then make and extra bend so you can have a crooked exhaust.
BTW...i don't like crooked exhausts....to each their own
Old Aug 11, 2004 | 10:49 AM
urquidezj's Avatar
Default Re: (manson)
6 no, 4 yes, im starting to back out. as long as i get 10 witch ever one gets there first i will do it, i like both styles so it doesnt matter. thanks
Old Aug 11, 2004 | 11:12 AM
13sechatch's Avatar
i didnt plan on mine going under the tank we just ran out of pipe. just route it regular cut your bumper out and have it come out the right side. thats how mine is im still workinon those pics.
Old Aug 11, 2004 | 11:14 AM
the_rail's Avatar
make that "7 no"
Old Aug 11, 2004 | 11:43 AM
87b16crx's Avatar
make it 8 for no. if you dont like the way it is done stock. just have them run it out the passenger side and cut a moon shape out of the bottome of the bumper. i dotn see any advantage to running it under the tank. just more **** to bottom out on i guess.
Old Aug 11, 2004 | 12:09 PM
urquidezj's Avatar
Default Re: (87b16crx)
8 no 4 yes
Old Aug 11, 2004 | 01:48 PM
tgreaves's Avatar
Mine is ran like that on my crx and it works great.. The shop I got it done at has done lots of them like that with no problem at all..
