idle and changing out distributor cap and rotor
Old Aug 10, 2004 | 09:05 AM
Xxcivic99xX's Avatar
Default idle and changing out distributor cap and rotor
Is it really neccessary to change these out? I wanted to know if I should change out my thermostat and spark plug wires? I have never changed these, and I have a 105K miles on my car. I have only change spark plugs every 20-25K miles, oil changes 3-4K miles, and drain and refill coolant every 20K miles.
Also I got a question. When my car is runnin at a constant idle, the RPM gauge stays steady but I can hear the car the idle, and it sounds as if its going up and down by a 100-200 RPMs. not even idle actually, when I rev it and hold it at 2-3K RPMs, u can still kind hear it
Old Aug 10, 2004 | 09:58 AM
im_poor's Avatar
Default Re: idle and changing out distributor cap and rotor (Xxcivic99xX)
105k miles, I would recommend you to change the spark plug wires, cap, rotor, check timing, timing belt, water pump, etc.
Old Aug 10, 2004 | 05:59 PM
blueeg's Avatar
Default Re: idle and changing out distributor cap and rotor (im_poor)
try cleaning out your throttle body too.
augustus
Jul 5, 2014 03:19 AM
lazieb29
Nov 22, 2009 09:34 AM
dth0ng69
Jun 28, 2008 08:04 PM
bizmackus
Feb 16, 2007 06:34 PM
ColfaxMax
Nov 23, 2004 06:08 PM
