Oil Pressure gauge
Old Aug 10, 2004 | 08:53 AM
crx_88_si's Avatar
Default Oil Pressure gauge
I need people to chime in and say how they have their's installed.
I've got mine on a t-fitting on the block, and a hose off that to the sender unit which is hanging off the intake manifold brace. My gauge needle bounces around alot, especially when i hit a little bump in the road.
I turn the car on and the needle PEGS to 100psi (max on gauge), sometimes it twitches there, sometimes it just stays solid there. then as it warms up it slowly lowers, and it's a little bouncy (VERY inconsistant). the only time it's steady is @ full warm idle, 15psi.
Oil 10w30 Castrol Syntec.
Old Aug 10, 2004 | 09:41 AM
CRX T-Si's Avatar
Default Re: Oil Pressure gauge (crx_88_si)
Damn I curious too, since I run an extension off the OP sensor to a Tee. I don't know where else I could mount it.
Pics would help.
Old Aug 10, 2004 | 09:47 AM
crx_88_si's Avatar
pics of mine?
Old Aug 10, 2004 | 09:49 AM
CRX T-Si's Avatar
Default Re: (crx_88_si)
no no, pics from other people. how and where they mount it.
Well it looks like your sender unit is bad.
Old Aug 10, 2004 | 09:56 AM
crx_88_si's Avatar
Default Re: (CRX T-Si)
sucks then cuz it's been this way since i've had it. seems to be better RIGHT after an oil change... then like 1 -2 days later, just bad again.
Old Aug 10, 2004 | 03:04 PM
paybac4223's Avatar
the only time my opg gives me any problems is about every 3-4 months i'll notice the needle bouncing around....i just have to tighten the bolt on the sender unit....
Old Aug 10, 2004 | 03:07 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (paybac4223)
The needle bounces when you hit a bump?, never seen that... What kind of gauge is it?
Old Aug 10, 2004 | 03:45 PM
USDM 4G VTEC's Avatar
i have T'ed off the block where the oil press sensor
i have a copper line to my autometer gauge on my dash.... i actually use a hole-saw and put it on the dash middle, the flat spot, and have it there....
its high on cold, and when the oil is warm, the readings are lower and normal
if it bounces all over the place, the guage is a POS... get a good one.
Old Aug 10, 2004 | 04:56 PM
krazie1's Avatar
BANNED
Default Re: Oil Pressure gauge (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed I never had a problem with my Autometer
Old Aug 11, 2004 | 03:22 AM
crx_88_si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paybac4223 &raquo;</TD></TR><TR><TD CLASS="quote">the only time my opg gives me any problems is about every 3-4 months i'll notice the needle bouncing around....i just have to tighten the bolt on the sender unit....</TD></TR></TABLE>
I'll try that too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">The needle bounces when you hit a bump?, never seen that... What kind of gauge is it?</TD></TR></TABLE>
Ractive. (Toucan industries)
Old Aug 11, 2004 | 07:12 AM
Synth124's Avatar
Default Re: (LSVTEC 91 Civic)
I'm just running an autozone sunpro?? oil pressure gauge, $16. Consistant pressure reading and no jumping when I hit a bump, not bad if you can't afford anything more expensive than $25
Old Aug 11, 2004 | 07:47 AM
crx_88_si's Avatar
yah im going to tighten the nut on the sender and i've got a tuner toys oil fitting coming in aswell.
http://www.tunertoys.com for info on the fitting.
basically it has an bspt -&gt; npt adapter built into a single piece. and it's steel, not brass. stronger.
Old Aug 11, 2004 | 08:41 AM
Driven's Avatar
How i did it:
1. Remove oil pressure sensor from back of block.
2. Install stainless steel line from Fast-Turbo.com.
3. connect OTHER end of line to a Tee-block.
4. strap the tee-block to the firewall (i used my brake lines).
5. reinstall oil pressure sensor to the tee-block.
6. Run other line to associated gauge.
this reduces any vibration issues that you'll have with running the t-block on the back of the engine.
Old Aug 11, 2004 | 08:45 AM
EJ1 wilcox's Avatar
Default Re: (Driven)
Here's how I did it...I just installed mine last week! The turbo should be on in a few more! Wahoo!
This way when I install my turbo I don't have to mess with anything for the oil supply, I can just hook right into the T on my firewall!
P.S. I got all of my oil fittings from Stan at Fast-turbo.com...he's a good guy
Old Aug 11, 2004 | 09:02 AM
i had 2 sunpros once and they sucked ***... worked great for 1 mth and then got fucked
i still got a sunpro voltage meter tho, works ok so far... just the oil press ones that suck for me
Old Aug 11, 2004 | 04:40 PM
crx_88_si's Avatar
Default Re: (USDM 4G VTEC)
ok.. I got a new 4-2-1 header installed tonight (the old one had a hole in the collector and it sounded like complete ***). anyways.. i wanted to see where my tiny oil leak was coming from. Surprise, surprise. from the hose that was feeding the Tee fitting for the oil sender and oem sensor. It was a loose hose clamp. We tightened it up a bit and when we started the engine to test the header the oil was gauge was nice and smooth and accurate.
On the way home. it started bouncing around again. :angry: Its ok.. i've got a proper fitting coming and Im going to be getting some AN fittings. no more damn barb's w/ clamps
btw.. BUMP
Old Aug 12, 2004 | 04:06 AM
crx_88_si's Avatar
ttt
CRXB16T
40
Jan 24, 2006 02:32 PM
2khb
Mar 10, 2005 06:52 PM
onlyneed4
Feb 2, 2005 05:08 PM
One8Hatch
Dec 25, 2001 12:09 AM
