Raising the Hood?!?!?!?
Old Aug 10, 2004 | 08:24 AM
6MTV6's Avatar
Default Raising the Hood?!?!?!?
How do I mod my 91 hatch to have the hood open up farther, like EG's and EK's?
Old Aug 10, 2004 | 09:33 AM
MonkeyMagic's Avatar
Default Re: Raising the Hood?!?!?!? (Bishop4G)
i put about 1/8 to 1/4 inch of washers between the hinges and the hood to give it a gap at the back of the hood and i noticed it seemed to open higher like my eg's hood... but the prop wouldn't hold it there so it was useless.
maybe if you do this or try bending up the back edges slightly and then cut an extra hole for the prop it'd work
have fun
Old Aug 10, 2004 | 09:39 AM
CRX T-Si's Avatar
Default Re: Raising the Hood?!?!?!? (MonkeyMagic)
Why may I ask??
Take a look at the Hood Hinge, there is a limiter there. If you want to raise it higher like the EG/EK then just shave it a little to your liking.
Old Aug 10, 2004 | 10:26 AM
6MTV6's Avatar
Default Re: Raising the Hood?!?!?!? (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Why may I ask??
Take a look at the Hood Hinge, there is a limiter there. If you want to raise it higher like the EG/EK then just shave it a little to your liking.</TD></TR></TABLE>
Because I'm 6'3" and when I work in my bay, I have to duck under the hood. When I remember...
Old Aug 10, 2004 | 10:31 AM
91civicEX's Avatar
the hood on my 89 goes all the way up. i like it more, i can do swaps without takin the hood off. on my 91 it goes normall hight. maybe its a 88-89 90-91 thing.
Old Aug 10, 2004 | 11:14 AM
6MTV6's Avatar
Default Re: Raising the Hood?!?!?!? (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">the hood on my 89 goes all the way up. i like it more, i can do swaps without takin the hood off. on my 91 it goes normall hight. maybe its a 88-89 90-91 thing.</TD></TR></TABLE>
Do me a favor and see what the difference is between your 2 civics.
Old Aug 10, 2004 | 11:18 AM
temp's Avatar
why not try using EG hood hinges?
Old Aug 10, 2004 | 11:21 AM
Crakadic's Avatar
My 91 goes up all the way without a prob. I have no washers and stock hinges.....
6MTV6's Avatar
Default Re: Raising the Hood?!?!?!? (temp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp &raquo;</TD></TR><TR><TD CLASS="quote">why not try using EG hood hinges?</TD></TR></TABLE>
I'm hoping I can use 88-89 ones. If possible. I didn't know you could just swap in EG hinges.
Old Aug 10, 2004 | 11:23 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G &raquo;</TD></TR><TR><TD CLASS="quote">
I'm hoping I can use 88-89 ones. If possible. I didn't know you could just swap in EG hinges. </TD></TR></TABLE>
i dont know if you can, its just a suggestion, i cant imagine that the bolt pattern is that different, and if it is maybe you can use the base part and the upper from the EF, as far as i know the 88-89 opens the same as the 90-91
Old Aug 10, 2004 | 11:42 AM
6MTV6's Avatar
i dont know if you can, its just a suggestion, i cant imagine that the bolt pattern is that different, and if it is maybe you can use the base part and the upper from the EF, as far as i know the 88-89 opens the same as the 90-91</TD></TR></TABLE>
Not quite. This guy from my local Honda board has an 88 CRX that opens up far like the EG's and EK's.
Old Aug 10, 2004 | 11:58 AM
vitrox's Avatar
my 89 opens all the way up, there is no place to put the arm into, but youc an easily cut something out of there.
Old Aug 10, 2004 | 12:01 PM
6MTV6's Avatar
Default Re: (vitrox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vitrox &raquo;</TD></TR><TR><TD CLASS="quote">my 89 opens all the way up, there is no place to put the arm into, but youc an easily cut something out of there.</TD></TR></TABLE>
The prop rod is the least of my worries. I know I can drill/dremel a hole into the hood skeleton to hold it up.
My hood only goes up like maybe 3 more inches. I'll have to see if I can put the EG hinge base on the EF hinge.
Old Aug 10, 2004 | 12:10 PM
insomniac791's Avatar
yes I would be interested in doing this to my 91 crx it dosen't open very high. It is much easier to work on my bros 93 hatch with the hood all the way up....
Old Aug 10, 2004 | 01:57 PM
sinfultrends's Avatar
Default Re: (insomniac791)
wouldnt that make a gap in the hood line in the rear so the hood would be slightly propped up?
i use to have that on my 240sx for heat purposes.. didn't notice a increase in hood clearance when i opened it
maybe hondas are different
Old Aug 10, 2004 | 02:00 PM
t0eKnEe's Avatar
Default Re: (sinfultrends)
I cracked my fuGGiN windsheild trying to raise my hood up as far as it looked like it could go when I was swapping my motor. Here we are a year and a half later and I still havent replaced it.
Old Aug 10, 2004 | 03:13 PM
6MTV6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinfultrends &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt that make a gap in the hood line in the rear so the hood would be slightly propped up?
maybe hondas are different</TD></TR></TABLE>
It's not actually raising the rear side of the hood. At least I won't do it to my car. I'm thinking I may have to cut and weld some hinges together. Then I can make a 'J' shaped bracket to clear the defroster vent trim.
Old Aug 10, 2004 | 03:19 PM
Default Re: (Bishop4G)
i see... yea raising the rear looks kinda funny but its a must if u have lots of engine bay heat or you could get a vented hood..
Old Aug 10, 2004 | 04:43 PM
lsrex212's Avatar
ok, dont swap the hinges, look at the ed (ef) hinges...on the hinges there is a limiter like stated above...if you loosen the lower part of the hinge you can swivel the limiter dealie out of the way, then you can have full tilt on your hood....and on the hood, standing at the front facing back, there is a hole in the hood below and to the left of the original hood prop hole...you have to bend the top part of that hole in and then you can use that to hold the hood...works great for me....i can take pics in the morning if you want...
Old Aug 10, 2004 | 08:22 PM
temp's Avatar
Default Re: (lsrex212)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsrex212 &raquo;</TD></TR><TR><TD CLASS="quote">ok, dont swap the hinges, look at the ed (ef) hinges...on the hinges there is a limiter like stated above...if you loosen the lower part of the hinge you can swivel the limiter dealie out of the way, then you can have full tilt on your hood....and on the hood, standing at the front facing back, there is a hole in the hood below and to the left of the original hood prop hole...you have to bend the top part of that hole in and then you can use that to hold the hood...works great for me....i can take pics in the morning if you want...</TD></TR></TABLE>
yes.....take t3h pix
Old Aug 11, 2004 | 06:48 AM
6MTV6's Avatar
That's tight. I would appreciate a pic if possible.
Old Aug 11, 2004 | 05:28 PM
pics would be good
Old Aug 11, 2004 | 06:04 PM
temp's Avatar
bump for pix
chunkybs
Jul 22, 2006 09:53 AM
97jdmdc2gsr
Mar 2, 2006 05:34 AM
BigBlockCRX
Audio / Security / Video
109
Dec 19, 2004 08:27 AM
MikeyDB7
May 15, 2003 10:04 AM
