Progress camber kit and omnipower coilovers - what ride height for -1.5 degrees
Old Aug 10, 2004 | 05:06 AM
Mr.Saturn's Avatar
Default Progress camber kit and omnipower coilovers - what ride height for -1.5 degrees
Just like the title says, what ride height and what setting in the front do I need for -1.5 degrees camber?
Old Aug 10, 2004 | 08:14 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Progress camber kit and omnipower coilovers - what ride height for -1.5 degrees (Mr.Saturn)
Don't you just set your desired ride height and then set your camber with your camber kit???
Old Aug 10, 2004 | 08:39 AM
Mr.Saturn's Avatar
Default Re: Progress camber kit and omnipower coilovers - what ride height for -1.5 degrees (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">Don't you just set your desired ride height and then set your camber with your camber kit???</TD></TR></TABLE>
Progress camber kit is the hard mount type with only 2 settings, one for low, the other for lower. Getting a good starting point and then adjusting camber through ride height will be much much easier.
Old Aug 10, 2004 | 08:41 PM
Mr.Saturn's Avatar
nvm, hole 2 is +.75 degrees hole 1 is +1.75 degrees, hole 2 with a 2-2 1/4" drop is good i think
19Accord97
Suspension & Brakes
Mar 12, 2009 01:07 PM
sohcd16
17
Feb 26, 2009 11:28 PM
ITR_1211
Honda S2000
Apr 14, 2005 01:15 PM
CrX-To-Tha-Max
Mar 4, 2004 07:17 PM
slvrcivic97
Oct 17, 2002 05:57 PM
