can the JDM fog light switch work with an after market fog lights ?
Yes you just need to make a relay setup to provide power to the lights and also get a plug from any integra cruise control button as it will plug into the jdm fog switch
Hey Mike, what about the OEM fog lights? Do they come with a relay, or will I need to make a relay for those as well with then being a factory Honda part?
OEM lights come with the relay, harness and shiet, maybe even the USDM plug. Just swap to the JDM plug and you'll be all set......
OEM Fog light kits (In the US) come with wiring switch relay etc. to use the JDM switch you would need to cut off the us switch plug and put a plug for the jdm switch
If you have to make a relay kit its actually very easy
I have some PIAA fog lights and got the jdm switch off ebay. i just took apart the PIAA switch and soldered the wires to the jdm switch. adds a nice little touch to the car. the ony thing is i didn't hook it up to the dimmer so the light is always on in the switch
SupaMonkey
Sep 16, 2008 04:07 AM
95ej1
22
Mar 6, 2005 04:00 PM
PokeyD16Z
Jan 20, 2005 03:18 PM
