Removing heater core
Old Aug 9, 2004 | 07:32 PM
Losrocket_'s Avatar
Default Removing heater core
Ive removed all the a/c and heater components from the car. I'd like to remove the heater core also but theres two lines coming out of the motor, through the firewall and into the heater core. Can i "loop" these two lines into eachother or plug them? Ive never done this so im not sure what to do with them. Thanks for the help!
Old Aug 9, 2004 | 07:55 PM
Losrocket_'s Avatar
Default Re: Removing heater core (Losrocket_)
I did a search and one thread came up. Somebody said to remove the outlet fitting from the head and install a threaded plug, then remove the thermostat housing and have the inlet from the heater core welded shut.
It sounds easier to just loop it. Anyone know if looping it is a bad idea or would it be safe? Thanks again.
Old Aug 9, 2004 | 08:20 PM
zccr-xsi's Avatar
lol dude i had same prob theres a bolt on the outside on the firewall take it off it will come right out,
i fought with mine for 3 hours before i found that bolt
Old Aug 9, 2004 | 08:24 PM
Losrocket_'s Avatar
Default Re: Removing heater core (vteckillenzc)
It took me about an hour before i realized the bolt is on the opposite side of the firewall. Ive got it covered how to take it out im just unsure of what to do with the coolant lines that run into the heater core. What did you do with yours?
Old Aug 9, 2004 | 08:28 PM
Driven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Losrocket_ &raquo;</TD></TR><TR><TD CLASS="quote">im just unsure of what to do with the coolant lines that run into the heater core.</TD></TR></TABLE>
just get a fitting that connects the two lines together.
You could even install a water temp sensor in the fitting and connect a temp gauge too it.
wait, nevermind, just keep it simple, just loop them. you'll be fine.
Old Aug 9, 2004 | 08:29 PM
Ya wanna race's Avatar
You can loop the one line on to the other, all the do is carry radiator fluid, or you can plug it wich ever you prefer
Old Aug 9, 2004 | 08:37 PM
Losrocket_'s Avatar
Default Re: Removing heater core (JunkyardCrx)
Sweet! Ill just loop them, thanks very much for the help!
Old Mar 30, 2006 | 04:14 PM
tek_civic's Avatar
haha i know this thread is dead but... hahaha i KNEW there was another bolt on that mother! i have been yanking and twisting for like a half hour. i was just about ti get the sawzall out lol.. stupid bolt
meavey3368
Jul 12, 2014 11:29 PM
ej1love
Jul 18, 2009 08:15 AM
Dai_Ca_Vietnam_H22a4
Feb 9, 2006 02:09 PM
cc11386
Nov 2, 2005 01:31 PM
6ghatch
Apr 19, 2004 12:40 PM
