What makes the teg weigh 400 lbs more than eg hatch?
Old Aug 9, 2004 | 07:01 PM
Elemental's Avatar
Default What makes the teg weigh 400 lbs more than eg hatch?
Man Im dissappointed. The teg weighs around 2500 and the hatch weighs 2100. What makes the teg soo heavy? Anything worth removing? (non functional stuff)
like the rear wiper assy... what do power locks/windows/moonroof weigh?
Old Aug 9, 2004 | 07:08 PM
Nihilation's Avatar
omg.omg.exe
Old Aug 9, 2004 | 09:36 PM
Gerbilo's Avatar
Default Re: (Nihilation)
umm... there is a lot...
Integra is 172.4 inches long while an eg hatch is 160.2.... that's a biiig difference. all those options do weigh more as well...
Old Aug 9, 2004 | 09:49 PM
Cliffjumper2's Avatar
Default Re: What makes the teg weigh 400 lbs more than eg hatch? (Kyoushu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoushu &raquo;</TD></TR><TR><TD CLASS="quote">Man Im dissappointed. The teg weighs around 2500 and the hatch weighs 2100. What makes the teg soo heavy? Anything worth removing? (non functional stuff)
like the rear wiper assy... what do power locks/windows/moonroof weigh?</TD></TR></TABLE>
unless you have an RS, you're teg weighs closer to 2700 lbs than 2500 lbs. and the eg hatch you're referring to is the CX, the others weigh more.
the teg is bigger like gerbilo said; it also has a bigger glass hatch, a bigger motor, bigger wheels, disc brakes all around, (the cx has drums in the rear), the list can go on............but I'll let others continue it if they feel like it.
if you wanted an ultra light weight car, then you should go for a 88 crx HF. Otherwise why be disappointed
Old Aug 10, 2004 | 01:33 AM
irgaszm's Avatar
god that is scary that you guys know how long the damn car is....
Old Aug 10, 2004 | 02:28 AM
hammerdgolfer's Avatar
Default Re: (irgaszm)
all the ***** in the passenger seat and rear seats is what makes the integra weigh 400 pounds more,
hatchback=no *****
Old Aug 10, 2004 | 02:29 AM
sunroof is also 100 pounds of it
Old Aug 10, 2004 | 03:06 AM
sQwiReL bOi
Guest
Posts: n/a
Default Re: (hammerdgolfer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammerdgolfer &raquo;</TD></TR><TR><TD CLASS="quote">all the ***** in the passenger seat and rear seats is what makes the integra weigh 400 pounds more,
hatchback=no *****</TD></TR></TABLE>
word... all those ladies add weight
Old Aug 10, 2004 | 04:55 AM
ragejed's Avatar
Default Re: (sQwiReL bOi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sQwiReL bOi &raquo;</TD></TR><TR><TD CLASS="quote">
word... all those ladies add weight</TD></TR></TABLE>
Ya, but 400lbs worth? Ill take 3 girls, and cant go over a TOTAL limit of 350
Old Aug 10, 2004 | 04:59 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What makes the teg weigh 400 lbs more than eg hatch? (DCcliffjumper2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCcliffjumper2 &raquo;</TD></TR><TR><TD CLASS="quote">
if you wanted an ultra light weight car, then you should go for a 88 crx HF. Otherwise why be disappointed </TD></TR></TABLE>
GS-R is listed as 2590 lbs. curb weight I believe.
The only hatch anywhere near 2100 is the CX. The Si weighs in the 2400 range I think.
Old Aug 10, 2004 | 06:20 AM
GS-Rdriven's Avatar
Default Re: What makes the teg weigh 400 lbs more than eg hatch? (PatrickGSR94)
its not always about weight, depends on what you want to do..i mean if you are going to autoX who would pick a hatch over an integra...weight is not always that big of an issue, plus compared to all other cars, honda's are the lightest that you'll find so stop whining, why would be dissapointed integra's have so much more to offer IMO.
"god that is scary that you guys know how long the damn car is...."
I know right, but that's why am here.
m R g S r's Avatar
Some things you don't need:
Rear wiper/motor assembly
AC System
Power Steering System
Rear Seats
Plastics on Hatch
Rear Quarter/Trunk Plastics
Big *** metal bar under Rear Seats
Small steel or aluminum bar behind rear seats
Some other things for weight reduction:
Light weight wheels
Carbonfiber hood/Hatch/Sunroof block off
Lexan rear glass
And your teg should be a lot lighter!
Old Aug 10, 2004 | 06:48 AM
TrueUntilDeath.com's Avatar
Default Re: What makes the teg weigh 400 lbs more than eg hatch? (m R g S r)
the extra cam weighs it down
Old Aug 10, 2004 | 08:22 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hammerdgolfer &raquo;</TD></TR><TR><TD CLASS="quote">sunroof is also 100 pounds of it</TD></TR></TABLE>
Ive taken the sunroof out before and it does NOT weigh more then 35lbs or so. That minus the weight of the metal where the sunroof should be(in say an RS) is probably no more then 20lbs extra.
Old Aug 10, 2004 | 11:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
I use Edmunds.com, to get my factory specs, the 1994 integra gs/ls weigh 2,643lbs; a 1998 integra gs weighs 2,636lbs according to them, so 2,590 is a bit light.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">
Ive taken the sunroof out before and it does NOT weigh more then 35lbs or so. That minus the weight of the metal where the sunroof should be(in say an RS) is probably no more then 20lbs extra.</TD></TR></TABLE>
so you weighed it on a scale, or are these very rough estimates. The small piece of sheet metal in the place of the moonroof on a RS does not weigh 15 pounds. Please weigh your entire moonroof unit with a scale, and comeback with the results, otherwise, I don't see how it means much. If it is around 35lbs, that's still a good chunk of weight for a fairly useless hole in the middle of your roof.....just my opinion...if you wnat fresh air above your head, get an s2000....j/k
Old Aug 10, 2004 | 12:18 PM
Gerbilo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irgaszm &raquo;</TD></TR><TR><TD CLASS="quote">god that is scary that you guys know how long the damn car is....</TD></TR></TABLE>
hahahahaha!!!
Old Aug 10, 2004 | 12:35 PM
95 integra's Avatar
Yea that was a rough estimate....on the other hand I know how much 100lbs is and the sunroof is no where near that....thus Im a hell of alot closer to true weight then you are.
Old Aug 10, 2004 | 03:31 PM
gsrboi80's Avatar
Default Re: What makes the teg weigh 400 lbs more than eg hatch? (GMR MM12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GMR MM12 &raquo;</TD></TR><TR><TD CLASS="quote">the extra cam weighs it down</TD></TR></TABLE>
lololol
Old Aug 10, 2004 | 04:53 PM
Stewie's Avatar
Default Re: What makes the teg weigh 400 lbs more than eg hatch? (gsrboi80)
If I remember correctly, my 99 GS 5spd weighs over 2800lbs
I think my toyota taco weighs less. It gets better gas milage too. ah, time for a cold beer.
Old Aug 10, 2004 | 06:12 PM
Elemental's Avatar
ah. dont get me wrong. I am in no way dissappointed with my teg... well only that it is so heavy.
Old Aug 10, 2004 | 06:20 PM
B18 CYA's Avatar
i weighed my teg at the weigh stationa and it weighed 2574 with no one in it....97 gsr turbo....
Old Aug 10, 2004 | 06:41 PM
Default Re: What makes the teg weigh 400 lbs more than eg hatch? (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Yea that was a rough estimate....on the other hand I know how much 100lbs is and the sunroof is no where near that....thus Im a hell of alot closer to true weight then you are. </TD></TR></TABLE>
I'm sorry I must have missed where I gave a true weight for the sunroof unit.......oh, I didn't.
thus..........you are closer than what?????
anyway
Old Aug 10, 2004 | 06:50 PM
riceball777's Avatar
The only hatch anywhere near 2100 is the CX. The Si weighs in the 2400 range I think.</TD></TR></TABLE>
incorrect
all integras are over 2600 besides the rs
a 3rd gen gsr is 26xx colse to 2700 lbs
g2 are a lil lighter
a g2 ls is 2590
and a rs is about 2550
if you campare an integra to a eg si which is 24xx lbs the weight is less that 200 pounds and the si still doesent have power windows
stop comparing it to cx's
Old Aug 10, 2004 | 06:56 PM
Alchemist's Avatar
The B series engine probably weighs alot more than the D series.
Old Aug 10, 2004 | 07:00 PM
Elemental's Avatar
im just thinking of that video with the white turbo hatch and the infamous 515 whp gsr.
the hatch, with 300whp, was keeping up just fine. it just worried me a little bit.
