Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
For Sale: 1995 Integra GS-R H3/ITS Race Car
Old Aug 9, 2004 | 04:50 PM
krshultz's Avatar
Default For Sale: 1995 Integra GS-R H3/ITS Race Car
Edit 2-3-05: I have decided to take the car off the market. Slight change of plan, especially with the used race car market being as soft as it is.
The original post follows:
This is a difficult thing for me to do but the time has come for me to sell the Integra. Many of you know this car rather well.
<u>1995 Integra GS-R race car</u>
Purchased new in June of 1995, now built to participate in the NASA East Coast Honda Challenge. Here's what she's got...
<u>Drivetrain</u>:
- B18C1 1.8L VTEC Motor
- Stock 4.4 final drive
- JDM Integra Type R limited slip diff
- Timing set to 19deg. advance (recommend race gas)
- Mobil 1 from mile 1000
- Mocal 19-row oil cooler with Aeroquip high pressure lines and fittings
- Remote oil filter adapter with sending units installed for Autometer oil temp and oil press gauges. I have the gauges in hand, have not finished the install yet.
- DC Header with custom-fabbed 2.5' collector out to rear exit 2.5" straight pipe exhaust.
- AEM cold air intake
- All-metal radiator
- Brake and clutch cylinders replaced at 90K
- A/C deleted
- Brand new ACT clutch and pressure plate with maybe six track days on it
<u>Safety</u>:
- Interior gutted to ECHC / IT specifications
- Fully custom, 7 point (missing driver side firewall bar, thats all) Kirk Racing cage. Fully triangulated and stiff - the car will sit on three jackstands (!). NASCAR driver side door protection, petty bar, integrated custom seat mount, window net
- Sunroof replaced with sheet steel (still have the original pieces)
- 5lb fire bottle mounted to cage
- 5 point TRW camlock harness (expired this year, will need replaced)
- Kirkey 17" road race seat
- I/O Port Racing seatback brace
- Custom-fabbed killswitch
<u>Suspension</u>:
- KONI single-adjustable (rebound) shocks with SPSS3 custom valving. Revalve perfomed at KONI NA has two weekends on it. This valving is good for up to 1200lb springs.
- Ground control front upper shock mounts
- Current alignment: 2.2 deg. negative camber, zero toe all four corners
- Eibach ERS Springs; 600lb front, 1000lb rear
- Progress 22mm rear swaybar, mounted at LCA pickups (NOT mounted at subframe, those tear out)
- Front upper control arms swapped for add'l 3 deg. caster
- SPC camber adjustable rear upper control arms
- Urethane bushings throughout
- 1 set Kosei K-1 15x7 38mm offset wheels. This is the magic set of numbers to fit a 225-45-15 Hoosier on a DC2 Integra. Shod with Hoosier R3S03s
- 1 set Enkei RF-1 15x7 38mm offset wheels. Shod with Hoosier Grand Am Cup tires that are not very useful anymore
- 1 set OEM Acura 15x6 wheels. No tires on these, good wheels for full depth Toyos for rains.
<u>Miscellaneous</u>:
- RoadRaceGear.com air dam and splitter package
- Integra Type R rear wing (not actually mine - might need to keep this. I still have the OE wing)
<u>Spares</u>:
Numerous ABS pumps and computers. Pair front knuckles with balljoints. Spare hubs, axles, wheels, brake pads, lots of stuff. I've owned this car for ten years so I've probably got considerable "Integra Pieces" laying around the house that I don't even know about.
<u>Accident damage</u>:
No major accidents its whole life. Years ago I put it up on the curb at a street autocross so the radiator core support is a little tweaked. The passenger side door has some dents in it from contact with a fellow racer. That's it.
<u>Problems and issues</u>:
First and foremost it's got a bad driver side axle. I will repair this before sale. There is a minor exhaust leak where the header meets the rest of the system. Some of the gauge lights (backlighting for the tach/speedo) are intermittent.
<u>Where can I race it</u>?
Any club racing program where it's legal - Improved Touring S with SCCA, Honda Challenge H3 with NASA. Take the petty bar out of the cage, put in a passenger seat, install a muffler, and you've got a fast and safe HDPE car. Other road racing options exist too.
In the THSCC Time Trial program it has gone undefeated in all classes it has run in since the inception of the series. During various stages of the car's development it has run in D Street Prepared and ITS. In 2001 this car took third place overall both days among some very fast company.
<u>Whats it drive like</u>?
This is a fast FWD road racing car. It turns in RIGHT NOW and drop throttle oversteer is tuned into the car by design.
<u>How much</u>?
Best offer over $10K takes it all. Firm. That means "No, I will not take $9K or $8K or $9,900." I am also not interested in parting the car out. I am not interested in selling any of the spare wheels - they are part of the spares package being included with the car.
I have that much in modifications to the car alone; there is very easily $30,000 invested in this car over the last 9 years. Quite possibly more than that - I'm afraid to add it up.
Interested? Questions? kshultz at nc dot rr cot com, or 919-454-4775. Serious inquiries only. And if you email, please make the subject line clear so my spam filter doesn't wack it.
Modified by krshultz at 4:05 PM 8/10/2004
Modified by krshultz at 4:40 PM 2/3/2005
Old Aug 9, 2004 | 05:07 PM
SicNA94TegGsR's Avatar
Swollen Member
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (krshultz)
damn Karl...hate to see you go just as im getting mine together...(finaly)
Old Aug 9, 2004 | 05:11 PM
Catch 22's Avatar
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (SicNA94TegGsR)
This is a very good and extremely well cared for car. A steal at that price.
Old Aug 9, 2004 | 06:10 PM
.RJ's Avatar
.RJ
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (Catch 22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Catch 22 &raquo;</TD></TR><TR><TD CLASS="quote">A steal at that price.</TD></TR></TABLE>
If I had a truck and trailer I'd be all up on this shiz
Old Aug 9, 2004 | 06:15 PM
Back in Black's Avatar
Rather OG
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (.RJ)
10k? What a deal. Maybe it's time for me to sell, too...
...nah!
Seriously, great price for a very well taken care of car. Bump for Mr. Uber.
Old Aug 9, 2004 | 06:49 PM
MaddMatt's Avatar
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (Jason Franza)
After I drove this car at a Viper Days event a few years ago (and embarassed the f@ck out of everything that didn't have "Team Oreca" decals and air jacks on it) I started calling it "Black Crack".
So I guess a THSCC spec E36 M3 is in your future??? Can I help you sort it??
Seriously, very to see this go. It spent more time in my garage in Durham than some cars I owned.
Old Aug 9, 2004 | 07:35 PM
tnord's Avatar
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (MaddMatt)
hmmm...........
2 race cars CAN'T be a good idea. although i do have the perfect parts car already.
wish we had NASA out here in kansas. or at least ITS rules that let the car be competitive.
good luck selling.
Old Aug 9, 2004 | 07:39 PM
Willard's Avatar
motor and shell mileage?
clean title?
Old Aug 9, 2004 | 07:42 PM
phat-S's Avatar
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (tnord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">wish we had NASA out here in kansas. or at least ITS rules that let the car be competitive.
good luck selling.</TD></TR></TABLE>
I really wish you guys hadn't all dog-piled on this GS-Rs can't be competitive stuff. There is one car it (and the rest of ITS) won't do well against. And that, with the current look of things may very well change. Unless you will be running against a fleet of E36 325s all prepped to the max, a fully sorted GS-R will be at the front of the pack - I got money on it. I wish I had enough money to buy one to prove it.
And yes, absolutely good luck selling it
Old Aug 9, 2004 | 07:43 PM
krshultz's Avatar
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (Willard)
128,641 on shell, motor and trans. Clean title.
Old Aug 9, 2004 | 07:44 PM
Shaun K's Avatar
Wow, so you're going to be like me and sell your track car right after you finally find the Powerstroke tow vehicle you've been searching for? What's next for you?
Old Aug 9, 2004 | 07:48 PM
MaddMatt's Avatar
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (Shaun K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">What's next for you?</TD></TR></TABLE>
my guess:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">a THSCC spec E36 M3 </TD></TR></TABLE>
Old Aug 9, 2004 | 07:52 PM
MEANB18's Avatar
Nice Nice car, I'll have to keep this in mind... post up some pics if you got em?
Old Aug 9, 2004 | 07:56 PM
tnord's Avatar
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (MEANB18)
i'll wait until the adjustments are made before i jump into ITS. no reason to leave the best class going in SCCA .
Old Aug 9, 2004 | 08:08 PM
Catch 22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun K &raquo;</TD></TR><TR><TD CLASS="quote">What's next for you?</TD></TR></TABLE>
We're going to spend 2005 teaching brother Karl how to race.
krshultz's Avatar
A number of people have asked me why. Well, I've had this car for about a decade now, and to be honest, I'm ready for something different. Whatever it ends up being will be a "track car" only - not a wheel to wheel racer. I've decided I'm done with owning sedan based racers - next *race* car I own will be a sports racer of some sort...something built and designed to be a race car, not a street car.
What's next? I dunno. Shaun you're right...good time to get a high dollar tow rig, right before selling the race car What's next depends on how much I get for the Integra. On the list are / have been...
- E36 M3
- CRX Si, possibly with a swap
- Something "interesting" under the hood of my commuter BMW 325
- Mustang or F Body or some sort of Corvette
- Any number of other "interesting" cars including Porsche 944 Turbo, bone-stock WRX, MINI...
PICTURES:
This one's a couple years old and still shows the long-gone bolt-in cage.
This one is current with the exception of the missing RoadRaceGear.com splitter and air dam:
Will look for some more.
Old Aug 9, 2004 | 11:03 PM
Shaun K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krshultz &raquo;</TD></TR><TR><TD CLASS="quote">
- E36 M3
Yeah, I made the same smooth move buying my F250 right at the time when my CRX became a garage queen. Oh well, my wife wants a slide-in camper for it, so keeping it can be justified
This gets my vote
I really love the Factory Five kits...either the street model or the spec racer is ok with me. I'm seriously thinking of selling my CRX for one. I guess I miss Mustanks too much.
Good luck with the sale, Karl. It seems like a really great deal.
Old Aug 10, 2004 | 10:50 AM
trhoppe's Avatar
I have a WRX with your name on it
Could I daily drive this thing?
-Tom
Old Aug 10, 2004 | 11:10 AM
krshultz's Avatar
Default Re: (trhoppe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trhoppe &raquo;</TD></TR><TR><TD CLASS="quote">Could I daily drive this thing? </TD></TR></TABLE>
Not without considerable pain and financial suffering...
Old Aug 10, 2004 | 11:13 AM
Brian*'s Avatar
Default Re: (krshultz)
hmmm.... so you want an E36 M3?
Brian
-who wouldnt mind seeing his go to good hands
Old Aug 10, 2004 | 01:15 PM
JohnW's Avatar
Gonna miss ya brotha!
$10K = Gooot deal!
John
Old Aug 10, 2004 | 07:14 PM
whitney's Avatar
I had the pleasure of driving this car for a few laps at speed during a school at VIR South course. (I believe MaddMatt, Bowie, and I are among the few people that have had a chance to try it on track ... Thanks Karl! He took my 325is out for a few laps and came back complaining about the understeer )
I totally agree with MaddMatt's "Black Crack" comment. It's amazing how solid, smooth, and fast Karl's car felt compared with my old H4 Civic. Made the damn Civic feel like a British car in comparison.
Old Aug 11, 2004 | 04:11 AM
MaddMatt's Avatar
Default Re: For Sale: 1995 Integra GS-R H3/ITS Race Car (whitney)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I totally agree with MaddMatt's "Black Crack" comment.</TD></TR></TABLE>
After I split between 2 Vipers going into the turn 1 braking zone, Karl said "Don't get all red-misty with my car man..." Or something like that. I wasn't listening much.
Old Aug 11, 2004 | 11:42 AM
SPiFF's Avatar
Maybe this?
Rice .. you better at least bring that thing out for SEHC @ Roebling next month!!!!!
Old Aug 16, 2004 | 03:25 PM
Cochise's Avatar
Default how about this?
not an E36 M3 but as many horsies.
http://www.bimmerfest.com/foru...66948
