H22a / stroker kit / full-race stage 3
Im building a new engine mostly for racing in the SFWD category. Sometimes i might take it out on the street. Im working with what i have which is a H22a motor.
I know about b18b, b18c engines and how well they do. need info + opinions oh the h22a motor.
Lay out:
H22a "built" 90mm
stroker kit, longer rods, bigger crank...ect....more torque
full-race kit
GT40/ t4 .58a/r
jun cams
speed pro EMS
Lay out:
H22a "built" 90mm
full-race kit
GT40/ t4 .58a/r
jun cams
speed pro EMS
who's sleeving it? alot of the shops that sleeve h-series dont suggest going over 89mm bore for f/i. going 90mm doesnt leave any room for error... Also why the jun cam over crower turbo cam or skunk2's? how much power u tryin to make?
im not buying the jun cam , just taking the specs and getting mine custom grinded for chaper.
My motor does not have any sleeves , fully sealed.
650hp , I will be using 550hp to 650hp at the track , what ever it can handle at the track with out ******* up the tranny to much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.83Tc »</TD></TR><TR><TD CLASS="quote">im not buying the jun cam , just taking the specs and getting mine custom grinded for chaper.
650hp , I will be using 550hp to 650hp at the track , what ever it can handle at the track with out ******* up the tranny to much. </TD></TR></TABLE>
that is a contradiction. good luck with the h tranny. but if you need gears for it i can get them for you.
you dont need that much bore and stroke to make the power
keep the stock crank and go with 87 or 88mm bore with a 10:1 comp
and ill go a little bigger on the turbine with a h22 trying to make that much power
am running a .69 t4 but no dyno numbers with it yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.83Tc »</TD></TR><TR><TD CLASS="quote">My motor does not have any sleeves , fully sealed. </TD></TR></TABLE>
How is it "fully built" without any sleeving? Sleeving is a crutial part to having that much power. And H22s have Fiber Reinforced Sleeves, which makes it nearley impossible to run forged internals. Maybe you know something we dont.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poorguy »</TD></TR><TR><TD CLASS="quote">a stroker crank would require shorter rods not longer ones. why stroke it and go with such a small turbo, the turbo's just gonna choke you.</TD></TR></TABLE>
very true.
very true.
Typically you run a longer rod along with a shorter compression height when doing a stroker, I don't know of ANYONE who runs a shorter rod in conjunction with a stroker kit.
