Y8 manifold - pics/details please!
Old Aug 9, 2004 | 10:32 AM
4drEF's Avatar
Keyboard Humorist
Default Y8 manifold - pics/details please!
I'm trying to see what people have come up with for the throttle cable install.
Temporarily I have flipped the Y8 bracket over and can only run one screw for the mounting bracket.
The cable is loosened as much as possible, but still seems to be just ever so slightly too tight. I'm not exactly sure if it is yet as the engine hasn't been fired yet.
So, what's everyone else doing?
Old Aug 9, 2004 | 01:01 PM
DualCamDan's Avatar
Default Re: Y8 manifold - pics/details please! (4drEF)
you can just use an 87 crx throttle cable bracket! thats what i'm using. good luck
Old Aug 9, 2004 | 02:06 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Y8 manifold - pics/details please! (whitey_4g)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitey_4g &raquo;</TD></TR><TR><TD CLASS="quote">you can just use an 87 crx throttle cable bracket! thats what i'm using. good luck</TD></TR></TABLE>
Perfect fit?
Uses both mountng screws?
Room for cable adjustment?
Old Aug 10, 2004 | 12:47 AM
DualCamDan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
Perfect fit?
all you have to do is drimmel out the bolt holes a little bit. fits great. like factory
Old Aug 10, 2004 | 05:08 AM
solorexer's Avatar
Why not just use the 96+ ex throttle cable? Its only about 12 bucks from a honda dealer...
Old Aug 10, 2004 | 06:56 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Y8 manifold - pics/details please! (solorexer)
I am using the 90/91 LX/EX accelerator pedal with cruise. The fitting on the end of the cable is different than the one on the 88~91 Si.
I can only imagine that the fitting will be different on the 98 EX as well.
There are 2 throttle wires (they call it a wire... not cable?!?!?) to order from Honda for the 98 EX. I could get them both and only spend $20. I'm just not sure which to buy and if either of them would work.
4DRmafia
30
Nov 10, 2008 11:59 PM
88 rex
Jul 9, 2005 07:33 PM
90hbvtec
Nov 13, 2003 02:47 PM
RAWB
Jun 23, 2003 12:59 PM
fastcrxsi90
Mar 20, 2003 01:10 PM
