Should I turbo???
Old Aug 8, 2004 | 09:23 PM
HS2G's Avatar
Default Should I turbo???
I'm looking to buying this 95 prelude Si with 87,000 miles on it for $7000 good price? If I buy this prelude my plans are to tune it with hondata and turbo it. Would the 87,000 mile engine be reliable for boost?
Old Aug 8, 2004 | 09:26 PM
Behan's Avatar
Default Re: Should I turbo??? (HS2G)
7000 seems a litlle steep but the mileage is fairly low. Check http://www.kbb.com for price.
As far as the turbo, read this thread
https://honda-tech.com/zerothread?id=316373
But to answer your specific question. Yes, your engine can be safely turboed at 87,000 miles. As long as its in good condition.
You need to make sure it is running correctly/no problems.
Old Aug 8, 2004 | 09:31 PM
Taikonaut's Avatar
I agree with Behan, that price is pretty high for a 95 Si. With that much you might be able to find a decent 5th gen or a 4th gen VTEC.
As for the turbo, check the compression on each of the Cylinders to make sure they are in good shape and the numbers and are within 20psi of each other.
Modified by Taikonaut at 6:58 AM 8/9/2004
Old Aug 8, 2004 | 09:40 PM
Behan's Avatar
Default Re: Should I turbo??? (Taikonaut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Taikonaut &raquo;</TD></TR><TR><TD CLASS="quote">.
As for the turbo, check the compression on each of the Cylinders just to make sure they are in good shape and the numbers and are within 20 psi of each other.</TD></TR></TABLE>
Fixed that for ya.
I searched to find the usual psi for an h23 compression test, i didn't really find a conclusive answer, but 160 seeemed like a consistent reading for an h23. If you want the exact number from the manual i can check it later.
Old Aug 8, 2004 | 09:57 PM
Taikonaut's Avatar
Default Re: Should I turbo??? (Behan)
haha thanks
Old Aug 8, 2004 | 09:59 PM
blackdelslo's Avatar
Make sure to do everything right... no half assing anything and you should be fine.
Old Aug 9, 2004 | 01:22 PM
SpoolinSiR's Avatar
yes to turbo
Old Aug 9, 2004 | 02:12 PM
preludeez's Avatar
Default Re: Should I turbo??? (junb16si)
you should only turbo if you understand what a turbo set up requires (parts, knowledge, and maintenance), if you do - go for it! if not - learn - then go for it.
as to the mileage - as mentioned - do a compression test first and go from there.
Old Aug 9, 2004 | 02:17 PM
LudaMan's Avatar
Look what I can do!
Default Re: Should I turbo??? (preludeez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeez &raquo;</TD></TR><TR><TD CLASS="quote">you should only turbo if you understand what a turbo set up requires (parts, knowledge, and maintenance), if you do - go for it! if not - learn - then go for it.
as to the mileage - as mentioned - do a compression test first and go from there.</TD></TR></TABLE>
agreed, make sure you know what youre getting into. Spend some time reading up on it and learning first, and do it right and once you go boost you never wanna go back!!
Old Aug 9, 2004 | 02:26 PM
TxTuner
Guest
Posts: n/a
Default Re: Should I turbo??? (LudaMan)
$7000 is very steep for that year lude, esspecially an Si. It really doesn't matter what the mileage is on the engine if you focus your attention to rebuilding it and preparing it for boost (most of the preparation for boost cuts out parts of the rebuild anyway). I recently bought a 92 Si for $700. The body needs a little work as well as the interior but I bought the car for the engine. With 170k miles on it, I'm rebuilding, setting up for boost, and throwing it in my 95 accord.
waytoosnoozed
Sep 24, 2018 10:12 PM
livelifefast
Aug 2, 2004 05:14 PM
Root79
Feb 2, 2004 10:56 AM
viet4gvtec
Apr 24, 2002 03:34 PM
showlude
Feb 15, 2002 08:01 PM
