clutch cable help?!?!?
Old Aug 8, 2004 | 07:29 PM
honda06si's Avatar
Default clutch cable help?!?!?
ok i got a 90 crx si and i put a b16a in it and i am having trouble with the clutch cable..its like the bracket isnt right...do i cut the cable or do i modify the bracket???
Old Aug 8, 2004 | 07:33 PM
Redline130's Avatar
Default Re: clutch cable help?!?!? (honda90si)
As long as you are using the bracket from the B16 tranny, you shouldn't have any trouble.
Old Aug 8, 2004 | 07:39 PM
EL Vap133's Avatar
It would be easier to use a Teg clutch cable.
Old Aug 9, 2004 | 12:03 AM
quik89's Avatar
yeah, or what i did was just flip that bracket upside down and it worked, that was for an 89 civic sedan, , don't know if it's the same for your car.
Old Aug 9, 2004 | 12:40 AM
RC_SKUBY's Avatar
Default Re: (quik89)
yeah its pretty hard to get the stock civic cable to get in there, it would be easier to use one out of the integra if you have one on hand. But it is possible just mess with it for a bit.
Old Aug 9, 2004 | 06:16 AM
CRX T-Si's Avatar
Default Re: (skuby_do)
I have the Teg one in my CRX and it's still a bitch to get the cable around that freeking little loop on the tranny.
Lot better then the CRX one.
Old Aug 9, 2004 | 08:39 AM
Rywire's Avatar
Default Re: (CRX T-Si)
You can cut some excess from the rubber boot, that works great.
Old Aug 9, 2004 | 08:41 AM
manson's Avatar
Default Re: (droppedcrxsi)
im using the teg one... no problems.
Old Aug 9, 2004 | 10:52 AM
quik89's Avatar
Default Re: (manson)
yeah, go with the teg one
Old Aug 9, 2004 | 02:48 PM
5litereater's Avatar
if you dont wanna buy anything, flip the bracket (may need to shave it down a bit) and it'll work perfectly. that's what i did with my b18 swap
stegs
May 6, 2008 07:27 AM
rewerbcrx
Jan 17, 2006 09:56 AM
joeyandhiscrx
Jan 21, 2004 04:43 PM
hndarcrb18c1
Oct 5, 2003 10:14 AM
