I need new spark plug wires. What do you recommend?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 »</TD></TR><TR><TD CLASS="quote">just like title says.
what do you have or recommend?</TD></TR></TABLE>
OEM Honda, which are made by Sumitomo.
OEM wires, even 10+ year old ones, have been dyno proven to outperform aftermarket wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">OEM Honda, which are made by Sumitomo.
OEM wires, even 10+ year old ones, have been dyno proven to outperform aftermarket wires.</TD></TR></TABLE>
Where is the dyno sheet then? I have a set of MSD wires, my car runs better with those than it does with the stock wires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">
Where is the dyno sheet then? I have a set of MSD wires, my car runs better with those than it does with the stock wires.</TD></TR></TABLE>
Right here.
So where is your proof? Plug wires making your car run better? Pfft, sounds like the placebo effect if I've ever heard it . . .
Right here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">Right here.
So where is your proof? Plug wires making your car run better? Pfft, sounds like the placebo effect if I've ever heard it . . .</TD></TR></TABLE>
I don't see MSD in there... I have better gas mileage, and smoother revs with the MSD super conductors.
Needs to be About 20% Cooler
ok narowed it down to NGK, MSD, or OEM. If you were getting a new set, of the three, what would you get?
I had some yellow 8mm Idontrememberthebrand wires and the Test Only smog guy was shocked like fifty times (I counted) trying to put the timing thing on the wire. Needless to say he told me to buy "stock" NGK ones. I listened to him.
ngk, or if you get a good deal like i did, msd...they costed me $35 bucks and were new...they made my engine a lot smoother and helped out a bit on the gas mileage...
but then again my ngk's were about a year old...
