S.O.S.>> Crank Pulley queston..
Just recieved my JDM B16A..
Crank Pulley is MUNCHED.. it was off an ITR that had bad crash apparently (the pulley)..
anyway, I need to know if my D16Y1 SOHC VTEC crank pulley can be used on the B16A as a replacement pulley is over $350 AUD !!
SOS as my swap is booked in for the 16th August and I need to have ALL parts ready in time..
thanks for your reply, but I need some more definate info before I drive down to the workshop.. the D-series crank is on the D which is still on my car..
ONE person said the diameter was different ? I dont know what the crank pulley needs to be in sync wwith..
I don't believe you can swap a D series crank pulley with a B. I know that all B series will work on each other, but I really don't think the D will.
hmm well at least any B-series is OK.. that's a start..
but man am lookin at $350 AUD > $250 USD just for a inert lump of metal !!
I mean I dont quite know what the pulley is attached to - does it just drive the Auxillaries (power steering and alternator ? or what ?
if that's the case - it shouldnt matter too much should it ?
OK thanks for your more definate answers..
$30 USD = about $40 AUD sob sob.. if only you guys were here HAHAHA
$350 AUD = about $280 USD
EVERYTHING Honda is expensive over here - it sucks !!
BTW, I am ditching Air-con, but retaining Power steering..
billard
May 20, 2011 10:05 PM
