EG/H22 RPM HOOK UP (HELP)
Old Aug 8, 2004 | 03:48 PM
mdj_ge's Avatar
Default EG/H22 RPM HOOK UP (HELP)
i have a 2001 H22a, does anyone in here knows how to hook up the RPM to the Distributor... i don't see any wire to hook it up.... Help Please...
Old Aug 9, 2004 | 06:40 AM
93H22ACX's Avatar
Default Re: EG/H22 RPM HOOK UP (yangja)
what do you mean hook up the RPM to the distributor?
Old Aug 9, 2004 | 06:48 AM
Jason kiDD's Avatar
If you are referring to hooking up a tach or shift light then it is the blue wire on the drivers side harness that you tap into.. Or if you feel adventurous you can tap into it by the distributor and run a long *** line back to your cluster..
Old Aug 10, 2004 | 07:11 PM
mdj_ge's Avatar
actually, i'm refering to hooking it up to the distributor... i don't have that blue wire coming out from the distributor... it's a 2001 model, i don't know if they have it....
Old Aug 10, 2004 | 09:29 PM
v4lu3s's Avatar
RTFM
i have not yet seen a honda that doesnt use a blue wire from teh distributor to carry rpm signal to the ecu and dash.
Old Aug 12, 2004 | 06:32 PM
mdj_ge's Avatar
Default Re: (v4lu3s)
has anyone have a 2001 h22a with a tach install... i need help on this...
Old Aug 29, 2004 | 03:18 PM
mdj_ge's Avatar
Default Re: (yangja)
a quick question.... is it possible to put a D16z6 ICM to replace the OBD2's???
jj17
Jan 11, 2014 11:01 AM
1234567899876543211230
Aug 15, 2006 11:52 AM
ozzyman
Sep 29, 2003 01:39 AM
ozzyman
ozzyman
Sep 28, 2003 11:29 PM
