speedo cable???
Old Aug 8, 2004 | 03:33 PM
honda06si's Avatar
Default speedo cable???
ok in the back of the tranny for a b16a there is a speedometer cable and right beside that is two lines that i have no clue where they go any help????
Old Aug 8, 2004 | 04:02 PM
T--Rex's Avatar
Default Re: speedo cable??? (honda90si)
are you doing a swap with this engine?
Old Aug 8, 2004 | 05:35 PM
CRX T-Si's Avatar
Default Re: speedo cable??? (Matrix_Zero)
Use your original speed sensor.
The one you have is from a DA that uses Power Steering fluid.
Problem solved.
Old Aug 8, 2004 | 05:44 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
That is for "speed-assisted power steering.."
It is actually a small pump actuated by the speedometer drive..
What I did:
Loop a piece of 5/16" hose between the two and fill it
with power steering fluid for lubrication..
Old Aug 8, 2004 | 07:07 PM
T--Rex's Avatar
Default Re: speedo cable??? (88DXCRX)
looks good, but you can also just use your stock vss and speed cable. Fits in from a stock crx engine into any b-series swap.
Old Aug 8, 2004 | 07:25 PM
honda06si's Avatar
thanks alot for the pic...very helpful!!!
Hondakid4eva
Jan 26, 2011 06:16 PM
EF-Devotion
10
Jul 27, 2009 06:35 PM
NAIIAWAH
Jul 23, 2006 10:07 AM
Hondasaurs
May 15, 2003 08:32 AM
takeheed
Sep 22, 2002 05:59 PM
