How do you pull a Check engine light code from 2002 Accord EX???
Old Aug 8, 2004 | 10:57 AM
joestud's Avatar
Default How do you pull a Check engine light code from 2002 Accord EX???
I need help pulling a Check engine light code from a 2002 Accord EX. THanks
Joe
Old Aug 8, 2004 | 12:07 PM
tsdenny's Avatar
Default Re: How do you pull a Check engine light code from 2002 Accord EX??? (joestud)
use a paperclip:
jumper the service connector
turn the ignition key to ON
count the flashes on the instrument panel
then, look up what the code means
Old Aug 8, 2004 | 05:37 PM
notoriousB's Avatar
Default Re: How do you pull a Check engine light code from 2002 Accord EX??? (6thgensohcvtec)
pins 8 & 13 in the aforementioned connector
Argenis 2524
Feb 5, 2016 11:48 PM
barfo
Feb 21, 2015 06:11 AM
swertepinoy
Oct 6, 2009 06:40 AM
2Accords
Sep 3, 2009 09:00 PM
lorenedopp
Nov 21, 2006 08:15 AM
