can i/should i bolt on ITR sway bar on 95 integ without other kit?
Old Aug 8, 2004 | 12:20 AM
oh-k's Avatar
Default can i/should i bolt on ITR sway bar on 95 integ without other kit?
will the itr sway bar bolt right on to my 95 integ without anyother kit or customization? and if so, is it a good idea that i do so? also i just plan to drive normally, little speed here and there, but no hanging turns on tracks, however i might make some sharp turns once in awhile. please let me know, thanks.
Old Aug 8, 2004 | 12:33 AM
silver00teg's Avatar
Default Re: can i/should i bolt on ITR sway bar on 95 integ without other kit? (oh-k)
you need a mounting kit because of the way it bolts to the subframe
Old Aug 8, 2004 | 12:46 AM
andrew dc's Avatar
Default Re: can i/should i bolt on ITR sway bar on 95 integ without other kit? (silver00teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver00teg &raquo;</TD></TR><TR><TD CLASS="quote">you need a mounting kit because of the way it bolts to the subframe</TD></TR></TABLE>
yup
BSQ or beaks
Old Aug 8, 2004 | 02:19 AM
Dc2 Powered's Avatar
how much would it cost for the everything to install the sway on a 95.
Old Aug 8, 2004 | 06:36 AM
ebelp's Avatar
Default Re: (Dc2 Powered)
Here's my archived swaybar install thread I made when I had my 94 gsr:
https://honda-tech.com/zerothread?id=424452
kenzo42
Oct 28, 2011 04:08 PM
diagnostic
May 17, 2006 07:06 AM
spog
Oct 11, 2004 01:26 PM
yoda888
Feb 6, 2004 10:59 AM
plusONE jboy
Nov 27, 2003 11:16 AM
