installing rear strut bar?
Old Aug 7, 2004 | 09:33 PM
accord450's Avatar
Default installing rear strut bar?
hi, i just bought a rear upper strut bar for my accord. ive been told that it goes in the trunk, but i dont know how to install it. i lifted the carpet in the trunk and i dont see any place to bolt it. i would appreciate any help.
thanks guys
Old Aug 7, 2004 | 09:39 PM
fw190bvi's Avatar
Default Re: installing rear strut bar? (accord450)
what year car???
pull back the carpet, pull down the rear seats, and youll see the rear strut towers.....there ya go
Old Aug 7, 2004 | 09:41 PM
KTeller8's Avatar
Default Re: installing rear strut bar? (fw190bvi)
where your sturts bolt to the car..
you ll see the bolts
Old Aug 7, 2004 | 10:52 PM
dvsOasis's Avatar
i've been out of the scene for years, but got bored and decided to check out some pics and whatnot. anyway, if i remember correctly, you have to cut out your trunk lining in order to bolt that on. Some people just cut out a X into the lining and feed the bar through it, while others just cut out a square out of the lining and mounting through that.
Just don't get the lower rear strut bar...it's useless crap...you can't even look at it unless you look under and specifically look for it (spare wheel well in the way)....so don't even get it for aesthetic reasons.
btw, you probably have the front strut bars...see how they're mounted at the top of the struts? The rear upper strut bar is just like that, but in the trunk....but since you have the lining in the way, you have to cut it like i mentioned before
Tippyman
Welding / Fabrication
22
Oct 21, 2006 02:24 PM
g07ph0
Dec 25, 2005 07:07 PM
bk11383
Apr 5, 2005 04:57 PM
nutonu
Mar 13, 2005 04:01 PM
