can a 89 si clutch work with a 91 tranny or not the same
Old Aug 7, 2004 | 04:27 PM
racingant's Avatar
Default can a 89 si clutch work with a 91 tranny or not the same
just as it says
Old Aug 7, 2004 | 05:13 PM
racingant's Avatar
Default Re: can a 89 si clutch work with a 91 tranny or not the same (racingant)
bump
Old Aug 7, 2004 | 05:18 PM
mar778c's Avatar
Community Builder
Community Influencer
No, the splines are different. You have to have the same year model clutch and flywheel.
Old Aug 7, 2004 | 05:21 PM
crxgator's Avatar
Default Re: can a 89 si clutch work with a 91 tranny or not the same (mar778c)
88 has the different splines...
89-91 same spline count
90-91 have a bigger clutch disc...
Old Aug 7, 2004 | 06:44 PM
jlicrx's Avatar
yes, if you have 89 flywheel
Old Sep 6, 2004 | 02:17 PM
Layziebtnh055's Avatar
Default Re: can a 89 si clutch work with a 91 tranny or not the same (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">No, the splines are different. You have to have the same year model clutch and flywheel.</TD></TR></TABLE>
I have a 89 civic dx, what if i get a 91 si tranny, your telling me it wont work????what clutch will i need
Old Sep 6, 2004 | 08:08 PM
ACTman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">88 has the different splines...
90-91 have a bigger clutch disc...</TD></TR></TABLE>
What he said! Take it to the bank.
If you can, use the 90-91 clutch since it is bigger/better. The 92 and newer are also the same except for the release bearing on the 92+ (hydraulic system) is different.
classciv
Jun 22, 2007 08:41 AM
shadycrx
Jan 2, 2006 10:08 PM
dstudent
Nov 2, 2004 09:06 AM
Donkey85
Jul 27, 2004 03:24 PM
civteg1
Sep 29, 2002 10:24 AM
