Timing Belt change/Oil Pump question?????????
Old Aug 7, 2004 | 01:45 PM
tedjones's Avatar
Default Timing Belt change/Oil Pump question?????????
I know there are many posts on timing belt changes and related problems, however, I did not see anything like this in the archives.
'90 Accord LX - timing belt broke, changed both timing belt and balance belt and wter pump. After putting everything back together, now my oil pressure warning light comes when the car is running. Not at first, but after it warms up and tryinto drive it. Is it possible the belt tension is incorrect? Would loose belt tension prevent the oil pump from turning enough to keep the proper pressure when the engine is uner load?
Need help ASAP. Thanks in advance!
uberEFtuner
Feb 9, 2010 07:10 AM
Stan Koehn
Jul 25, 2009 03:19 PM
zhen_fai
Aug 25, 2007 07:39 AM
92TEGsrSC
Jul 23, 2003 10:16 PM
MugenHonda
Nov 16, 2002 08:47 AM
