giant goodbye h-t.com sale. a$$hole rearended my crx = now a honda civic crx smashback.
dont ask the details, please this hurts too bad. anyways, the following items are for sale.
ls 402t cams 300
ls 403 cams 300
stock cams 50
cam gears 20
head b18a bigger w/ 1mm oversize valves with p/p 600
intake manifold 50
valve cover1 30 b18a
valve cover2 30 b18b
2 falken azenis/w steelies 195/60/14 300
225 50 15 rims/tires package (rim is helo screech) 600
racaro copycat seats 400
turbo kit for 90-93 teg ls2000
stock header 35
crx ball joints (front)40
radiator 200
built axles (fidanza 500 hp) 400
stock axles 100
stock clutch 10
stock flywheel 30
stock pressure plate 10
act clutch 150
act flywheel 150
act pressure plate 150
b18a cable transmission 300
clutch cable 20
93 integra speedo 80
b18a crank 200
b18a block 100
b18a rods 50
b18a 93 teg wiring harness 50
crx b series motor mounts 100
crx tokico suspension 300
make offers. i am open to negotiation.
subject to change!
ls 402t cams 300
ls 403 cams 300
stock cams 50
cam gears 20
intake manifold 50
stock header 35
radiator 200
stock axles 100
stock clutch 10
stock flywheel 30
act clutch 150
act flywheel 150
clutch cable 20
b18a crank 200
b18a block 100
b18a rods 50
subject to change!
Do you have the outer tie rods and upper ball joint suspension parts? If so, are they new or same mileage as the car?
Sorry to hear about your loss
You willing to part the upper ball joints and outer tie rod ends? Obviously if you can get them off without jacking them all up.
sale ended. i found a white 89 crx for $500 (non running but in good shape). all i will do now is sell the crower 403 and stock ls cams, valve springs and retainers. sorry folks good luck came my way
