ITR LCA and ITR Sway Bar - HELP!
I'm installing ITR Rear LCA and ITR Sway Bar and ITR Shocks and Springs on a GSR. Can I reuse the thing that connects the Sway Bar to the LCA or do I need to get a new one that works with the ITR LCA's? Please help, I already took my car apart.
Thanks
Thanks
You're talking about the endlink. I believe you can as i don't think they're much different. Just test fit it. If it doesn't work, you can drive without a sway bar to the dealer to get the ITR one (which is $$$ btw)
You can reuse the endlinks, but you'll probably need new bearing sleeves for the swaybar endlink bushings b/c they can get rusty and be really fussy about coming out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2ali »</TD></TR><TR><TD CLASS="quote">since you got the itr lca did you have to get one of those kits so that the sway bar would fit? like the beaks kit or that bsq kit?</TD></TR></TABLE>
Yes, you will still need a mounting kit, even with the ITR LCAs. The reason why, is because the non-Type-R Integras rear suspension subframe is different than the Type-R's.
