wiring problem, temp gauge is acting funny.
Old Aug 7, 2004 | 09:39 AM
BIG RICH's Avatar
Default wiring problem, temp gauge is acting funny.
OK, I've noticed sometimes that my temp gauge goes all all the way up past hot when I turn the car off. also the lights in the cluster stay on even after the key is out. I noticed that it does it when the doors are open, and if you close them the gauge goes down and the lights go off. It seems like a short but I don't know where to start.
Old Aug 7, 2004 | 10:32 AM
RCautoworks's Avatar
Default Re: wiring problem, temp gauge is acting funny. (BIG RICH)
Is this the stock gauge or aftermarket ? Check the grounds to start off with.
Old Aug 7, 2004 | 10:46 AM
91civicEX's Avatar
Default Re: wiring problem, temp gauge is acting funny. (90blackcrx)
check the main battery to chassis ground. when mine wasnt connected pressing the brakes would make the gauge cluster lights come on when the key wasnt even in the ign.
Old Aug 8, 2004 | 02:22 PM
BIG RICH's Avatar
Default Re: wiring problem, temp gauge is acting funny. (91civicLX)
it's the stock 89 dx cluster. i was thinking it could be a ground. where should i start? i looked over the engine to body, battery to body, and the thermostat grounds. they all looked fine.
Old Aug 8, 2004 | 03:46 PM
BIG RICH's Avatar
Also, the engine to body ground isn't in the factory location. I moved it one bolt up because I broke the original bolt in the hole and haven't gotten it out yet. could that cause the problem? I never had these problems before that. But then I didn't have them after it until recently, i broke the bolt a while ago(like 2-3 months).
Old Aug 12, 2004 | 10:06 AM
91civicEX's Avatar
make sure its got a good contact. on my battery cable the little bracket that bolts to the body broke so i just ran a wire directly from the negative terminal to above the headlight. works fine.
Old Aug 12, 2004 | 10:30 AM
5litereater's Avatar
could be your thermostat/thermostat ground.
Josephsnodgrass
Honda Civic (2006 - 2015)
Mar 2, 2017 01:57 PM
86RedFoxBodyGT
Nov 6, 2010 06:46 PM
mnskateboarder
24
Jun 23, 2009 08:28 AM
Dense
10
Jan 2, 2008 07:46 PM
daidilus
Sep 5, 2006 08:47 PM
