Integra Starts but dies in about 20 seconds
Old Aug 7, 2004 | 09:19 AM
Master23's Avatar
Default Integra Starts but dies in about 20 seconds
My integra starts for about 20 seconds and then it just dies. It dies with a check light but when i try to pull the code, i get nothing. I got a new distributor, spark plugs, new spark plug wires, and make sure all the grounds are on the frame. What else could be wrong with the car?
Old Aug 7, 2004 | 10:38 AM
SIK IN DA HED's Avatar
New User
did you check your idle? timing?
Old Aug 7, 2004 | 10:46 AM
PowerHouse's Avatar
Default Re: Integra Starts but dies in about 20 seconds (Jgears)
losing compression? if your car is losing to much compression due to blown head gasket or possibly bent valves, your car will shut down.
Old Aug 7, 2004 | 11:21 AM
Deep's Avatar
rule #1 when you got a problem dont always consider the worse first. Sure it could be all those other things but first try all your sensors, usually suspects are usually O2 sensors, or some kind of sensor, your ecu senses soemething wrong and is shutting the car down to protect it. Keep checking for codes,it has to throw something at you. Check your relays too, spark plugs, and your fuel system, it might be the pump or your filter. good luck.
Old Aug 7, 2004 | 11:25 AM
namechangeagain
Guest
Posts: n/a
Default Re: Integra Starts but dies in about 20 seconds (Deep)
try the altenator
RichN
Honda CR-V & Element
Feb 12, 2013 05:09 AM
civicxxman
Apr 27, 2008 01:52 PM
axionm1k
Apr 2, 2008 06:58 AM
Honda Hick
Feb 28, 2005 09:20 AM
g2turbo
Sep 17, 2003 08:31 PM
