b18b iacv?? for use on ITR/b16 manifold?
hey guys, well, after replacing my manifold with a aftermarket one the first gen. b16 iacv that i had broke into pieces. so, i have a extra b18b iacv which actually bolts up better on the manifold... but my question is can i use the non-vtec b18b iacv on my vtec set-up without any problems? thanks...
should work just fine, just take the 3 phillips head screws out of the bottom and clean it out on the inside to make sure it is not clogged. Since the iacv is on the back side of the manifold it is much easier to clean it now well it is not on the engine. Just use carb or brake cleaner to clean it out.
blackeg
Dec 9, 2010 06:22 AM
unified112
Jan 8, 2008 06:13 PM
evo
Apr 16, 2002 02:26 PM
