My DIY engine bay paint
Old Aug 7, 2004 | 02:03 AM
Jonathan_ED3's Avatar
Default My DIY engine bay paint
Washed, completely sanded, ready for masking and a final rub-down.
Masked, final wipe down done and ready for paint!
Painting. I had a few neighbors glaring at me. Oh well!
First coat
Second coat. This is primer if you cannot tell.
I left the tow hook on the driver side frame rail because the lower two bolts wouldn't come out. The nuts on the other side of the frame rail broke away from the spot weld or whatever and just spin freely =/
I'll probably do the color coat on sunday. It'll be Grand Prix White. I'm just trying to figure out if I should buy a smaller gun (touch up gun) to do the color coat....it was really hard getting the large gun in some of those areas even after adjusting the pattern down smaller. That and sanding in all those small areas is a real PITA.
Any advice for the color coat, sanding, clear etc?
Old Aug 7, 2004 | 02:07 AM
ophdehEEzY
Guest
Posts: n/a
i wonder what your neighbors thought!
for the diy!
Old Aug 7, 2004 | 02:14 AM
My neighbors hate me....I work on my car very late some nights. lol
FYI....and because somebody called me a dumbass in my other thread:
All the stock suspension is getting replaced, so it was of no concern to me that I painted the control arm posts and top of the strut.
I did take off the nuts so the actual unibody has uniform paint.
ilovemybeater's Avatar
Default Re: My DIY engine bay paint (Jonathan_EH)
DOH!!!!....you forgot to mask off your suspension!!!!...
Old Aug 7, 2004 | 02:17 AM
Read the post above yours
No overspray got on the outside of the frame rail anyway.
ophdehEEzY
Guest
Posts: n/a
Default Re: My DIY engine bay paint (ilovemybeater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemybeater &raquo;</TD></TR><TR><TD CLASS="quote">
DOH!!!!....you forgot to mask off your suspension!!!!...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonathan_EH &raquo;</TD></TR><TR><TD CLASS="quote">
Old Aug 7, 2004 | 02:18 AM
oops sorry didnt read the above post... for DIY!!
Old Aug 7, 2004 | 02:21 AM
I thought your avatar was a monkey until I took a closer look =/
Old Aug 7, 2004 | 02:22 AM
Default Re: (Jonathan_EH)
hahaha
Old Aug 7, 2004 | 02:54 AM
eJone powereD's Avatar
nicee
Old Aug 7, 2004 | 05:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Unless your car is going to be a super-d00per sh0w kaa then I wouldn't even bother with sanding. I would just do whatever is necessary to get paint and clearcoat into all areas.
Actually, most cars don't even have a clearcoat under the hood and in the engine bay, so spraying clear will already be going beyond the way it came from the factory.
Old Aug 7, 2004 | 07:32 AM
plusONE jboy's Avatar
done well for diy.
Old Aug 7, 2004 | 07:40 AM
XxSOHCDriVerxX's Avatar
Default Re: (DV)
came out real clean
Old Aug 7, 2004 | 07:58 AM
JapJunkie's Avatar
Default Re: (XxSOHCDriVerxX)
nice work.
Old Aug 7, 2004 | 09:45 AM
Default Re: My DIY engine bay paint (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Unless your car is going to be a super-d00per sh0w kaa then I wouldn't even bother with sanding. I would just do whatever is necessary to get paint and clearcoat into all areas.
Actually, most cars don't even have a clearcoat under the hood and in the engine bay, so spraying clear will already be going beyond the way it came from the factory. </TD></TR></TABLE>
I knew that Honda didn't put a clearcoat on there from the factory....but cars with aftermarket paint jobs have clear on there usually, don't they? They're very very bright so I assume they do.
I guess I'll just sand the major areas like the shock towers and crap before I shoot the rest.
Old Aug 7, 2004 | 10:34 AM
cd5_2NR's Avatar
damn, and i thought you were talking about you valve cover...not your actual engine bay...nice paint job...wish i had a paint gun...
Old Aug 7, 2004 | 11:19 AM
You can get a touch-up gun for ~$30-40! It's plenty big to do an engine bay.
Old Aug 7, 2004 | 12:21 PM
accordfreak's Avatar
hey how much pressure do you need to use the gravity paint gun properly? i'm thinking of buy a small compressor and using it to paint.
Old Aug 7, 2004 | 01:12 PM
_majik's Avatar
Old Aug 7, 2004 | 02:34 PM
Default Re: My DIY engine bay paint (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">hey how much pressure do you need to use the gravity paint gun properly? i'm thinking of buy a small compressor and using it to paint.</TD></TR></TABLE>
The gun I'm shooting with is best in the 35-50 psi range. Make sure to get a regulator! My compressor does 100+ psi....so a regulator is a must.
Old Aug 8, 2004 | 12:48 AM
G U E C O's Avatar
nice
Old Aug 8, 2004 | 12:54 AM
ill45's Avatar
Default Re: (DV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DV &raquo;</TD></TR><TR><TD CLASS="quote">Awesome dude </TD></TR></TABLE>
Old Aug 8, 2004 | 12:56 AM
Nate047's Avatar
Default Re: (ill45)
Old Aug 8, 2004 | 03:51 AM
Ekizzle's Avatar
Default Re: (DV)
blackANESE's Avatar
Default Re: (Ekizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ekizzle &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
