biggest wheels on an EF civic?
Old Aug 7, 2004 | 01:26 AM
crown14's Avatar
Default biggest wheels on an EF civic?
so who her has pushed the boundaries and actually ran the absolute BIGGEST wheel on their EF? tell me what size it is!
thanks
Old Aug 7, 2004 | 01:51 AM
rjay8604's Avatar
Default Re: biggest wheels on an EF civic? (crown14)
I would have to say 17's because your limited by tires, the wall becomes so thin with a 35 series tire, and they don't make a lower aspect ratio tire, so your limited to 17's which is too much in the first place IMO.
Old Aug 7, 2004 | 07:40 AM
crispydee's Avatar
Default Re: biggest wheels on an EF civic? (rjay8604)
a friend put 18'' on his with no problem and it lowered 40mm.
Old Aug 7, 2004 | 07:51 AM
1990hondadx's Avatar
Default Re: biggest wheels on an EF civic? (crispydee)
ive seen 22's but it also had like a 8 inch lift kit it was nasty the pimp factor was 100%
Old Aug 7, 2004 | 07:57 AM
temp's Avatar
there was a car in super street (a CRX) that had 18 inch volks on it
Old Aug 7, 2004 | 08:06 AM
crown14's Avatar
Default Re: biggest wheels on an EF civic? (temp)
i wonder what size tire you have to run with 18's
Old Aug 7, 2004 | 08:24 AM
redman223's Avatar
My friend had 18s on his rex a while back, they were nasty but its your money, so whatever floats your boat...
Old Aug 7, 2004 | 08:32 AM
HondaKPX's Avatar
Default Re: biggest wheels on an EF civic? (redman223)
Axis wheels put 19's on thier CRX
Old Aug 7, 2004 | 09:01 AM
CRXBart's Avatar
I ran 17's at one point. They are too big, I will not run anything bigger then a 15" now. I really like 14's amd 15's.
Old Aug 7, 2004 | 09:14 AM
SETI20's Avatar
16" is the biggest we will allow you to have.
Old Aug 7, 2004 | 09:15 AM
CRX T-Si's Avatar
Default Re: biggest wheels on an EF civic? (CRXBart)
The biggest wheels that you could put in an EF and still have it dropped would be 18"
How I know cause I had 18" wheels on my rust bucket before. Just need to roll the rear quarter panel a little and it won't scrap at all. Now the fronts will rub when you do a complete U-Turn.
The tire size that I had was 215-35-18.
19" will not be too streetable on an EF, show yes but not street driven. You will have to seriously modify the front and the rear so that the wheels fit and you can't drop it as you like unless you do a wide body CRX(which should never being done, just deface a beautify CRX).
I have pics my CRX when I had the rims on, go to my home page and check it out.
Note my AVATAR
Oh yeah it will lift your car like an 1 1/2" off the ground with the 18"s. Bottom line 18" will be the biggest anyone should go on an EF.
Old Aug 7, 2004 | 10:50 AM
temp's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">16" is the biggest we will allow you to have.</TD></TR></TABLE>
bwhahahahahaha
Old Aug 7, 2004 | 11:30 AM
StupidSlowRSX's Avatar
Default Re: (temp)
this question gets asked like once a week
Old Aug 7, 2004 | 01:06 PM
crown14's Avatar
Default Re: (StupidSlowCRX)
do you make worthless replies once a week too? or do you go read some more threads?
you knew what it was about, you clicked the link
Old Aug 7, 2004 | 01:46 PM
Default Re: (crown14)
yes, thats right, and im here to tell you that its posted once a week foo... run a seach if your really curious
noob
91efsikevs
Nov 16, 2008 05:37 PM
thorclark
Nov 13, 2008 07:36 AM
EF001282
Feb 10, 2008 07:28 PM
JaSoNe
Oct 25, 2006 11:03 AM
SNatCH 1.6
Sep 11, 2006 11:13 PM
