yep, another check engine question
Just finished an obd0 to obd1 conversion with a d16z6 into a 90 civic hb dx. everything runs perfect, but when hard shifting the check engine kicks on and the car will idle high... turn off the car then back on and everything is back to normal.
I cant pull the check engine codes because there is no DLC... check engine jumper connector... or what ever you want to call it. its just not there... i checked the harness that runs along the strut tower along the drivers side and dont see any cut wires. checked under the dash on the passenger side and nothing there either. Does anyone know what the wire colors are for the DLC so i can locate where it is suppose to be and check the code. chiltons manual sucks ***, doesnt even mention a DLC.
All help appreciated, thanks.
Ninja
http://www.kuruma-tuning.com
Ninja
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NinjaOfSRO »</TD></TR><TR><TD CLASS="quote">Thanks, thats exactly what im trying to do, just cant find the color code for the diagnostic link. C4 you say? ill check it out.</TD></TR></TABLE>
yo ed i emailed boomslang and they said the diagnostic link is d4 maybe thats why no code is showing up
cor4ey
Dec 20, 2008 12:42 PM
Untengijutsu
Sep 27, 2007 11:20 AM
NipponRacing
Jun 18, 2002 05:49 PM
