what to do with my block
my stock ls over heated due to a leak in my radiator that i did not notice, well i replaced the radiator but it seems like im loosing compression, well actually i am loosing compression, should i replace my piston rings or would i be better of replacing the block, wich is more costly and wich is more dependable, im thinking about buying a new block
thanks for the help in advance
if your block overheated, you might want to make sure you didnt warp the head. if everything is fine but youre losing compression, it really all depends on how much compression your losing and the inconsistency of the test.
Sport_Injected
Nov 11, 2004 07:43 PM
lke2drvgsr
17
Jan 17, 2004 12:44 PM
YOSOLO CRX
13
Nov 13, 2003 08:53 PM
