Which shocks to buy for 91 crx dx
Old Nov 29, 2001 | 11:06 AM
Krow's Avatar
Default Which shocks to buy for 91 crx dx
I am going to be getting some new shocks in the next week and I am looking for suggestions on which ones I should get. Post any positive and negative experiences that you have had with different shocks. Money is not an issue I just don't want to spend big bucks on something thats not as good as a leaser priced shock.
Old Nov 29, 2001 | 11:22 AM
keithv's Avatar
Default Re: Which shocks to buy for 91 crx dx (Krow)
What springs will you be using with these shocks?
Old Nov 29, 2001 | 11:26 AM
REDBARON's Avatar
Give more info..
Like at you mating them to lowering springs..are you putting coilovers...are you xcrossing or just daily driving??
Old Nov 29, 2001 | 08:19 PM
Krow's Avatar
Default Re: Which shocks to buy for 91 crx dx (VTECHatch)
I am going to be putting some coilover on also, and it is pretty much a daily driver for now. Once I get my swap done and get turbo kit installed it will be a street/ race car. So I will need some that are good at the track as well as the street.
[Modified by Krow, 5:20 AM 11/30/2001]
Old Nov 30, 2001 | 05:29 AM
keithv's Avatar
I'd get some Koni Yellows and Ground Control Coilovers. Its the best non-true coilover setup you can get.
Plus the Koni Yellows are adjustable so you can stiffen them up for racing and soften them for the street.
Old Nov 30, 2001 | 06:43 AM
Brandon Chun's Avatar
Default Re: Which shocks to buy for 91 crx dx (breaka_1_9)
The Koni Yellows are probably the best shock, but they are expensive. Since, you say youre getting coilovers they may be warranted though. Just my opinion, I like a spring better than a coilover for ride quality.
Old Nov 30, 2001 | 09:29 AM
Krow's Avatar
Default Re: Which shocks to buy for 91 crx dx (Brandon Chun)
Thanks guys, I am going out later to check out some shocks at a couple different shops. Like I said before money is no problem just want the best for my rex
mynameizstitch
Suspension & Brakes
Feb 17, 2009 04:24 AM
honda_coupe
Jan 27, 2007 01:23 PM
[HrZn]4life
Jun 19, 2003 12:15 PM
aguinald0
Aug 24, 2002 09:16 PM
khoa
May 15, 2002 07:49 AM
