92 Accord ABS to Non - ABS brakes conversion..Brake guru's please reply!
Old Aug 6, 2004 | 08:42 PM
tightDA8's Avatar
Default 92 Accord ABS to Non - ABS brakes conversion..Brake guru's please reply!
Hey, i just bought a clean 92 Accord from my cousin for an amazingly cheap sum. I plan to restore it and make it the clean cruiser it used to be....The car has some bugs that need to be worked out but the biggest bug is are the brakes. It has a new master cylinder, front and rear calipers, rotors, pads, But when the brakes are applied, it pulls to the left , then when released, jerks to the right....It could just be needing to be flushed out and re-bled, BUT i think it could be a fucked up ABS modulator...I checked the priced for a new or remanufacutured modulator, and its freakin expensive, so i thought about just converting it to non- ABS. Have any of you done this and can help me out? Some tips and tricks would be greatly appreciated.
-ray
Old Aug 6, 2004 | 08:52 PM
judonoh's Avatar
first off, you can pull the wire harness off the abs unit. The ABS light should come on, at this point there is no ABS. It will be back to standered, go driving and see how it feels.
Old Aug 6, 2004 | 09:02 PM
tightDA8's Avatar
Default Re: (judonoh)
thanks for the quick reply, i just did that and went down the street, it feels the same....Also, the brakes lock up easier., still pulls to the left, and jerks to the right, when i release the pedal....Wat do u think?
Old Aug 6, 2004 | 11:03 PM
disastar's Avatar
Default Re: (tightE46)
You probably have a sticking brake hose. When the rubber brake hoses get old, they can internally collapse and act as one way valves. When you apply the brakes, pressure builds up faster on the side with the sticking brake hose and holds pressure even as you release the brakes, until the hose un-collapses.
You should replace both front hoses and re-bleed everything. The master cylinder should have been bench bleed or it is probably damaged and may also be the source of your problem. If in doubt on proper bench and on-car bleeding procedures, take the car to a shop. Brakes are too important to play trial and error with.
Good luck!
Old Aug 7, 2004 | 06:55 PM
tightDA8's Avatar
Default Re: (disastar)
Thanks alot bro...I'll try it this week....I really need to get all of the little bugs worked out before i can start throwing money on apperace and cosmetic mods.
Old Aug 9, 2004 | 09:42 PM
tightDA8's Avatar
I just it it checked out by a shop that i trust and it looks like its the ABS modulator that it bad...NOW, i really want to convert it to non- ABS...has anyone here with an accord done this?
Old Aug 9, 2004 | 09:51 PM
iam7head's Avatar
http://www.accordinglydone.com...=4055
hit up accordinglydone.com, they have some great article there.
sidenote, no-abs on track felt really good but it cost me a set of kumho
Old Aug 17, 2004 | 07:39 PM
spurrierfan's Avatar
If you disconnected the wire harness from the abs and it did the same thing it was doing, it is not the abs. It is 2 independent systems. The brakes will work the same without the abs, to convert it to non abs just unhook it. Trust me I had an ABs modulator spring a leak on mine and it had no fluid for 6 months before I fixed it by putting another modulator in it and the brakes work fine without it.. Any factory repair manual will tell you the same thing, most manuals like Haynes, Chiltons etc. won't tell you a thing about the abs. Incidentally I bought a used ABS modulator for about $30.00 and I fixed my ABS with no problems. Like the other guy said it is most likely a hose problem or else you got ripped off on some of that hardware you already replaced.
Old Aug 17, 2004 | 09:00 PM
AngryTroll's Avatar
Default Re: 92 Accord ABS to Non - ABS brakes conversion..Brake guru's please reply! (tightE46)
Check your front, rubber brake lines. It sounds like the passenger line is twisted, probably when the brake job was done, or collapsed.
teamworxek9
Dec 29, 2008 10:21 PM
bonh
Jun 28, 2007 12:15 PM
boostedr
Jul 9, 2005 04:59 PM
raavango
Sep 3, 2004 03:31 AM
junglistgsr
Oct 6, 2001 06:53 PM
