knocking sound at slow speeds? axels or tranny?! help
i havnt got under the car yet but i am hearing a knocking sound when i slow down to slow speeds and also starting out at slow speeds. its getting a little worse and i need help desifering this problem. at first i thought it was the axels but now i am not so sure cause it might be happening when i put the clutch in at slow speeds. the clutch thing might also be my imagination so i was wondering it and one could help.
Start by grabbing the axle and trying to move it around. If one moves more than the other i'd replace the axles. I'd try to jack the front end up and manually turn each wheel. Check for any kind of resistance and obviously noise.
were you rough with the axles when removing? did you reuse existing ones or get new?
Frozen E
17
Oct 7, 2007 10:26 PM
f2m0u5
10
Dec 18, 2005 04:27 PM
