GSR swap throwing codes, got some questions
Old Aug 6, 2004 | 02:46 PM
shadykit's Avatar
Default GSR swap throwing codes, got some questions
Just finished my swap and it's throwing a knock sensor code which I double checked the wiring and it seems to be correct.
And it's also throwing cel code 1 which is primary O2 sensor.
what do I need to get it fixed?
Old Aug 8, 2004 | 11:54 AM
smart monkey's Avatar
Default Re: GSR swap throwing codes, got some questions (kitchale)
what car and what harness and ecu are you using? also make sure you have it all wired up right for the knock. as for the O2 it can be anything to wrong wiring or broken wires to bad O2.
Old Aug 8, 2004 | 05:46 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kitchale &raquo;</TD></TR><TR><TD CLASS="quote">Just finished my swap and it's throwing a knock sensor code which I double checked the wiring and it seems to be correct.</TD></TR></TABLE>
Did you use shielded wire with and supply the braided stand wire with a ground to shield out electrical interference's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">And it's also throwing cel code 1 which is primary O2 sensor.</TD></TR></TABLE>
What model/year car is the swap in? Some require rewiring of the O2 sensor if they aren't setup for a 4 wire O2 stock.
Old Aug 9, 2004 | 04:24 AM
shadykit's Avatar
Default Re: GSR swap throwing codes, got some questions (VTECVillain)
No I just used regular electrical wire. I'll try that though.
It's a 99 GSR swap so obd2a O2 sensors.
Old Aug 9, 2004 | 04:26 AM
shadykit's Avatar
OH it's on a 97 Civic Hatch.
EK k kay
May 29, 2006 09:54 PM
sadangryboi
May 10, 2005 02:03 PM
forcefedish
10
Oct 1, 2004 07:52 AM
incognitoracerr
Sep 25, 2003 02:45 PM
