DIY Trunk Brace 98% Completed!!
Old Aug 6, 2004 | 02:19 PM
TrueUntilDeath.com's Avatar
Default DIY Trunk Brace 98% Completed!!
tools needed. power drill, 5-6 diff size drill bits, wd-40, a table to work on, and fossil polarlized sun glasses to look cool while drilling
diff size drill bits.
after i finished the first hole
bolt length, later found out it is the wrong size.
what it will look like installed tomorrow
1" thick box bar (steel, not aluminim, but still hollow)
extra piece i cut off. test painted it orange i had laying around, will paint this color tomorrow, or black. not sure.
thanks for looking.
Old Aug 6, 2004 | 02:23 PM
vtec69's Avatar
Default Re: DIY Trunk Brace 98% Completed!! (GMR MM12)
i just installed one into my eg and i love it
Old Aug 6, 2004 | 02:53 PM
RidinStock's Avatar
Default Re: DIY Trunk Brace 98% Completed!! (vtec69)
to DIY and keep us posted.
Old Aug 6, 2004 | 03:48 PM
MooreBoost's Avatar
Default Re: DIY Trunk Brace 98% Completed!! (RidinStock)
Dont you think it would be more effective towards the center of the trunk, closer to the shock towers? I bet that area is weaker considering theres to it.
rufridn's Avatar
looks good. how much was the bar
Old Aug 6, 2004 | 03:56 PM
Default Re: (rufridn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rufridn &raquo;</TD></TR><TR><TD CLASS="quote">looks good. how much was the bar</TD></TR></TABLE>
8.89
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">Dont you think it would be more effective towards the center of the trunk, closer to the shock towers? I bet that area is weaker considering theres to it.</TD></TR></TABLE>
yea but the location i put it has already has 2 holes for bolts.
Old Aug 8, 2004 | 11:00 PM
Dc2 Powered's Avatar
Old Aug 8, 2004 | 11:03 PM
.water's Avatar
nice job..looking good...but my question is that will help what???
Old Aug 8, 2004 | 11:42 PM
Default Re: DIY Trunk Brace 98% Completed!! (SpoonKillerB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonKillerB &raquo;</TD></TR><TR><TD CLASS="quote">nice job..looking good...but my question is that will help what???</TD></TR></TABLE>
what do strut bars help? lol... right...
nothing. hah i duno if it will stiffen up the rear because i have not picked up the bolts for it yet so i cannot tell you how it is.
Old Aug 8, 2004 | 11:48 PM
when boredom hits
Old Aug 9, 2004 | 06:41 AM
vtec69's Avatar
Default Re: (Dc2 Powered)
well if you look at where this bar bolts into under the car you will see it bolts into the frame rails hence strengthing the frame, therefore makeing the rear end a little bit stiffer
-Brian
Old Aug 9, 2004 | 09:01 AM
JCushing's Avatar
i did the same thing except i used some bronze bushings in the box tubing to re-enforce the bolt whole.. (basically gives the bolt full contact all the way through)
and a helpfull tip to anyone loking to do this is if you have an ACE hardware they are an excelent supply of auto grade metric bolts
i was also thinking of remaking mine (although it is very sturdy) with a 2" solid aluminum round with the ends milled flat for bolts.
Old Aug 9, 2004 | 10:11 AM
Default Re: DIY Trunk Brace 98% Completed!! (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">i did the same thing except i used some bronze bushings in the box tubing to re-enforce the bolt whole.. (basically gives the bolt full contact all the way through)
i was also thinking of remaking mine (although it is very sturdy) with a 2" solid aluminum round with the ends milled flat for bolts.</TD></TR></TABLE>
the ace by me does not carry grade 8 bolts in metric
Old Aug 9, 2004 | 11:42 AM
StyleTEG's Avatar
Recently remade my trunk brace using forged endlinks and reverse threads, so I can put some preload on the brace.
My trunk looks disgusting because I never got all of the sound deadening out
I also plan to paint it soon.
Old Aug 9, 2004 | 02:41 PM
Default Re: DIY Trunk Brace 98% Completed!! (StyleTEG)
my finished product
Old Aug 9, 2004 | 02:52 PM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GMR MM12 &raquo;</TD></TR><TR><TD CLASS="quote">my finished product
Not bad
I made the mistake of not painting mine and mine started rusting like 2 days after i installed it
-Brian
Old Aug 9, 2004 | 03:29 PM
ChaseIntegra's Avatar
I've been thinking about doing that too, good job!
Old Aug 9, 2004 | 03:52 PM
cjohnson_2's Avatar
Default Re: DIY Trunk Brace 98% Completed!! (ChaseIntegra)
I like mine better.
Old Aug 9, 2004 | 03:54 PM
Default Re: DIY Trunk Brace 98% Completed!! (cjohnson_2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjohnson_2 &raquo;</TD></TR><TR><TD CLASS="quote">I like mine better. </TD></TR></TABLE>
did you make that or BUY it? hah
Old Aug 9, 2004 | 04:09 PM
vtec69's Avatar
wow yours looks much better but did you make that?
Old Aug 9, 2004 | 04:10 PM
cjohnson_2's Avatar
yes, i made it myself. made the 2 end pieces which a pice of tube steel slips into . had it welded professionaly for a box of doughnuts.. total cost 10 bucks 8 for the doughnuts and 2 for the bolts.
ATS*RON
Feb 22, 2006 10:07 PM
Stunna BEN
May 18, 2005 01:33 PM
ski_rebel_3
Honda S2000
Oct 5, 2002 02:28 PM
mrlegoman
Sep 22, 2001 06:04 AM
