B-series into EK.... need rear Si mount?
i was looking at the mounts on the hasport site and it says they are replacement but will fit d and b series...somehow that doesnt make sense to me.
The mount is the same configuration for both motors, it's the bracket that attaches the mount to the engine that's different.
brian g
brian g
oh ok thankyou for clearing that up for me...so you need the 99-00 si drivers side BRACKET that bolts to the moter and to the mount. anything else?
retain the sohc top trans mount/bracket (not the front vibration mount)
retain the sohc drivers side mount and bracket that bolts on to the top of it.
driver side post (bolts from block, to bracket listed above): any hydro b16
trans vibration mount: any year hydro 5 speed b series.
a/c bracket/engine vibration mount: any year b series hydraulic
(if you want to retain a/c, use a 94/95 del sol VTEC "P54" bracket)
rear trans "L" bracket: 99/00 si
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TECH43 RACING INC. »</TD></TR><TR><TD CLASS="quote">a/c bracket/engine vibration mount: any year b series hydraulic
rear trans "L" bracket: 99/00 si</TD></TR></TABLE>
will a 99-00 si ac bracket work on gsr motor into ek? instead of using a p54 bracket. I think its a p30 or somthing...cant remember...
Dj Lotte
Oct 7, 2003 09:09 PM
