exhaust for b series in ef hatch??
I tried searching, but I guess that I put one too many words in.. Anywho, what exhaust do I want to use JUST FOR BASIC OPERATION for a b18b in a ef hatch? I was told that a mildly modified exhaust from a ef hatch would work fine, BUT how? or is there an easier way? Details would be greatly appriciated, and if there is an aftermarket exhaust specifically for b series in an ef let me know, less headaches are better headaches. Thanks
Everything lines up fine, bolt patterns that is, but the pipe doesnt lay in routing in the underbody. by the way, what is an std.?
how is it not routed correctly if its the stock exhaust?
everything should be fine...the only problem i can think of ,is the exhaust wont reach the header..is that the problem?
you need to be more specific on what you want to know.
std= standard model
like dx and si ,std is a trim level. the lowest on the chain.
std= standard model
Actually i figured it out. I had a DC exhaust on a zc in an ef, i took that and just cut 3 3/4 inches off and it works fine. Thanks for the explanation also, I'm not to fluent with the typing jargin, And no its an SI
OLDSKOOL89SI
Nov 9, 2009 12:15 PM
trrbl1bmx
16
Sep 4, 2006 06:49 AM
