Clutch fluid getting dark after very little miles
I have changed out the clutch fluid 3 times in the past 3 months. In those 3 months, less than 1000 miles total with only 1 track event.
The fluid is dark again only after 200 miles or so.
Are there any reasons why it would get dark so fast?
Note: Using Honda Brake Fluid
Yep, in good shape. No cracks or hardening. Looks good. No leaks, resevoir area is clean as with the clutch lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">I have changed out the clutch fluid 3 times in the past 3 months. In those 3 months, less than 1000 miles total with only 1 track event.
Note: Using Honda Brake Fluid </TD></TR></TABLE>
this is very typical and not something to worry about.
It might be typical but still can't be good, dirt in the system will do damage after a while- maybe not next week but will.
I'd try to prevent it. I guess I got kinda lucky cause mine stay rather clean up till 10k miles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris N »</TD></TR><TR><TD CLASS="quote">Dust from teh clutch/pressure plate gets in the fl00id?
Chris - just guessing that is why.</TD></TR></TABLE>
Isn't the system sealed?
Foot -> clutch pedal -> clutch fluid pressure -> clutch slave -> shift fork
my guess is that the seals inside your clutch master cylinder are starting to go. I wouldn't worry about it until it doesn't do it's job anymore, then just change out the MC.
I had this same problem and ended up buying replacement Tokico OE ones (Master + Slave cylinder should always both be done at same time) from http://www.enthusiastsauto.com ... they were like $75.
Not a month later (I use Valvoline Synpower) the reservoir was getting dark again. It's a wear item...
phantom_sol
13
Sep 9, 2003 03:22 PM
