modifying stock injectors to have a greater flow rate?
Old Aug 6, 2004 | 11:53 AM
Black R's Avatar
25 Year Member
Default modifying stock injectors to have a greater flow rate?
A scooby friend of mine has sent his injectors somewhere that they modified and balanced them to flow 880cc/min...
Are there any sources that do such a modification to honda injectors?
Old Aug 6, 2004 | 12:09 PM
esponet's Avatar
the only thing i can think off, ie rc injectors, but i don't think they can make it that big.
Old Aug 6, 2004 | 12:11 PM
ZygSpeed's Avatar
Default Re: modifying stock injectors to have a greater flow rate? (Black R)
I'm sure RC Engineering could do it for you.
http://www.rceng.com/
I sent a set of my ITR injectors there once to have them cleaned and balanced (at 85K miles).
Good thing too, one of them was only doing ~180 cc/min whereas the other three were all around 238 cc/min.
Old Aug 6, 2004 | 12:43 PM
RStoR's Avatar
Default Re: modifying stock injectors to have a greater flow rate? (zygspeed)
Kenny - WRX/STi injectors use a flow cap to control flow rate. You can mod the injector by removing the cap. The injector flows approx. 740cc then. RC will do the mod for you, at a cost of $300 (as quoted on NASIOC). Appears you can do it yourself though as you just have to cut the cap off the injector. Here is the link;
http://forums.nasioc.com/forum...ctors
Old Aug 6, 2004 | 09:48 PM
Black R's Avatar
25 Year Member
Default Re: modifying stock injectors to have a greater flow rate? (RStoR)
That's great for the scooby folks.....
But what about us honda guys?
Old Aug 6, 2004 | 11:36 PM
IN VTEC's Avatar
I'd imagine that the pintle and orifice size would have to enlarged/bored out. That seems like a really time consuming procedure involving machining and possibly custom manufacturing of the pintle size.
It'd probably be easier to get a set of used RC injectors, a new set of generic Lucas disc-type injectors, or a set of MSD SCI injectors, which are all available for around $200 or less.
Old Aug 7, 2004 | 08:01 AM
SLCTyper's Avatar
Default Re: modifying stock injectors to have a greater flow rate? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I'd imagine that the pintle and orifice size would have to enlarged/bored out. That seems like a really time consuming procedure involving machining and possibly custom manufacturing of the pintle size.
It'd probably be easier to get a set of used RC injectors, a new set of generic Lucas disc-type injectors, or a set of MSD SCI injectors, which are all available for around $200 or less.</TD></TR></TABLE>
I agree. I don't have personal experience with modifying stock injectors, but from talking with people who have, it sounds as though it is about the same cost as just buying new injectors.
thanh4o8
Jun 5, 2009 04:28 AM
Jared
Sep 20, 2002 07:06 AM
b20b
Feb 5, 2002 09:14 PM
