High Idle after installing a Type-R throttle Body onto a b18C Skunk2 Manifold
Old Aug 6, 2004 | 08:06 AM
EF9-G'zer's Avatar
Default High Idle after installing a Type-R throttle Body onto a b18C Skunk2 Manifold
Can someone give me some tips on this problem? The only conclusions I've came across is that the throttle body is not sealing right, therefore extra air is pushing through the crease where the throttle body meets with the intake manifold. The throttle body gasket is brand new, so that wouldn't be the problem? Can someone give me some much needed advice? Thank you.
Old Aug 6, 2004 | 08:12 AM
crx_88_si's Avatar
check tps voltage.
Old Aug 6, 2004 | 08:20 AM
EF9-G'zer's Avatar
Default Re: High Idle after installing a Type-R throttle Body onto a b18C Skunk2 Manifold (EF9-G'zer)
I'll make sure to do that...but I isolated a leak by spraying some parts wash onto the bottom right, where the throttle body and intake manifold meet. I'm definitely clueless. Throttle body is torqued down to specs but I still have that leak in that area. Any suggestions?
Old Aug 6, 2004 | 08:32 AM
crx_88_si's Avatar
silicone it?
you sprayed the washer whatever there and saw it suck it in?
Old Aug 6, 2004 | 08:49 AM
EF9-G'zer's Avatar
Default Re: (crx_88_si)
Silicone what? Are you saying i should put hondabahn where the leak is??? The leak is located where the throttle body meets the manifold...when I spray parts wash into that section, my rpm drops from a whopping 2,000 rpm down to about 1, which in conclusion, there definitely is a leak causing my idle to jump up. Do you know what or how to fix this problem? Thanks man.
Old Aug 6, 2004 | 10:04 AM
ceLtic's Avatar
N/A wh0re!
Default Re: (EF9-G'zer)
car is running lean......add fuel some how...either vafc, chip ecu.....
Old Aug 6, 2004 | 10:20 AM
crx_88_si's Avatar
ya you could just put some silicone there. keep the car OFF until it hardens or you'll be sucking that crap into the motor. or, try another TB gasket.
Old Aug 6, 2004 | 10:30 AM
APEX CRX's Avatar
do you have the fast idle valve hooked up still? The valve under the throttle body?
Old Aug 6, 2004 | 10:37 AM
EF9-G'zer's Avatar
Default Re: (ceLtic)
What's that all about? If you read the post, I said I determined there was a leak where the throttle body meets the manifold. I replaced the TB gasket with a brand new integra type R one, and the leak is still located at the same exact place. And for the Fast Idle Connection...where is that located? I don't know if I even have it, etc. Thanks again.
Old Aug 6, 2004 | 10:45 AM
EF9-G'zer's Avatar
Default Re: High Idle after installing a Type-R throttle Body onto a b18C Skunk2 Manifold (APEX CRX)
If the fast idle valve isn't hooked up, wouldn't my ecu throw codes???
Old Aug 6, 2004 | 12:04 PM
gringo7718's Avatar
i had the same problem a month ago when i installed my gsr TB on my b16.
the fast idle thermo valve is located under your TB. mine does not have coolant running through it and it wont give a CEL. just do this trick and problem solved
https://honda-tech.com/zerothread?id=699787
Old Aug 6, 2004 | 02:19 PM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9-G’zer &raquo;</TD></TR><TR><TD CLASS="quote">
for the Fast Idle Connection...where is that located? I don't know if I even have it, etc. Thanks again.</TD></TR></TABLE>
here ya go
Old Aug 6, 2004 | 08:20 PM
EF9-G'zer's Avatar
Default Re: (APEX CRX)
COOL! I'll work on my car tomorrow...& hopefully this solves the problem. Thanks!!!!!!
spermdoggy
Jun 4, 2012 06:58 AM
92egboost
Jul 15, 2008 05:18 PM
Bakersfieldgsr
Nov 12, 2007 03:34 PM
jwamp316
Oct 26, 2005 01:49 PM
