Head gasket help?
Old Aug 6, 2004 | 07:27 AM
gt25CIVICex's Avatar
Default Head gasket help?
hey, im changing my head gasket this weekend and i was reading a really good post on hg problems on a boosted d16 yeasterday. anyway i noticed that alot of you guys are useing a "copper spray" when you put the new hg on. what exactly is it and where do you get it? thanks.
Old Aug 6, 2004 | 08:09 AM
ladysman's Avatar
Default Re: Head gasket help? (gt25CIVICex)
Copper spray is just that, copper spray.
I use it with only positive results.
You MUST make sure you apply it in even light coats. Let it dry completely before installing.
Old Aug 6, 2004 | 08:32 AM
Turbo E's Avatar
funny, im changing my HG too. i picked up a can of VHT copper spray (adhesive) for like $5 and a set of ARP head studs.
when you say apply 2 light coats. do i want to almost color the HG or just a light dusting?
Old Aug 6, 2004 | 09:57 AM
EM1 MIKE's Avatar
Copper spray-a-gasket is a sealant.
You can pick it up at any Pep Boys or AutoZone for about $5.
Old Aug 6, 2004 | 10:14 AM
ladysman's Avatar
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">
when you say apply 2 light coats. do i want to almost color the HG or just a light dusting?</TD></TR></TABLE>
I put I think 4 coats on it but VERY light ones.
Old Aug 6, 2004 | 11:50 AM
Turbo E's Avatar
thanks ladysman! exactly what i wanted to see
Old Aug 6, 2004 | 12:18 PM
Evs-One's Avatar
Solbros Owns Me
you don't need to let it dry either. On the can it even says, just to wait till it;'s tacky at least.
I usually spray a generous amount when I use it
I re use head gaskets because of this stuff
Old Aug 6, 2004 | 03:57 PM
ladysman's Avatar
Default Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">you don't need to let it dry either. On the can it even says, just to wait till it;'s tacky at least.
I re use head gaskets because of this stuff </TD></TR></TABLE>
I would never reuse a HG (nor does Honda recommend it).
Mine set for a week and was very tacky. When it dries, it is always tacky.
Old Aug 6, 2004 | 05:31 PM
RyanEJ8's Avatar
Default Re: (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
Mine set for a week and was very tacky. When it dries, it is always tacky. </TD></TR></TABLE>
I only let mine sit for like 15 min when I coated it with copper spray.
Old Aug 6, 2004 | 07:07 PM
Evs-One's Avatar
Solbros Owns Me
no one should recommend re using a head gasket.
Old Aug 13, 2004 | 05:16 PM
Turbo E's Avatar
BTW sorry for the thread Hijack
okay im about to pull the head off the B18C. any tips or pointers? do i need to drain anything?
-i will pull the turbo mani off
-remove timing belt and cams
-disconnect sensors and hoses from intake mani (leaving on head)
spray the gasket w/copper spray before install
Old Aug 13, 2004 | 05:49 PM
B2FiNiTY's Avatar
Drain the oil and coolant.
Old Aug 13, 2004 | 05:50 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (B2FiNiTY)
yea, good idea.... i drained my coolant when i did my headgasket'
remeber to re-torque all your head bolts to factory specs'
Old Aug 13, 2004 | 05:52 PM
B2FiNiTY's Avatar
Default Re: (kKdARIAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN &raquo;</TD></TR><TR><TD CLASS="quote">yea, good idea.... i drained my coolant when i did my headgasket'
remeber to re-torque all your head bolts to factory specs'</TD></TR></TABLE>
There is also a specific order you need to tq AND to tq it a certain amount before applying full tq to it.
This is one of those things you DO NOT want to mess up.
Old Aug 13, 2004 | 06:56 PM
NLR808's Avatar
sometimes you got to make due with what you got and if it works use it and who the hell listens to the honda dealership
Old Aug 13, 2004 | 07:09 PM
99blackcivicSi's Avatar
Default Re: (NLR808)
i have NEVER had a problem reusing a head gasket just make sure you don't reuse a blown one, but when i blow one you can tell i blew it
Old Aug 13, 2004 | 07:26 PM
VTgringo's Avatar
Default IMPORTANT!!!!!!!
Yes, you have to let the copper spray dry for a bit. I'm an engineer and we do a bit with sealants like copper spray, only we use sodium silicate. The copper spray is in liquid form because it needs to be sprayed from the can. The actual sealant is a solid. The liquids must evaporate from the spray once it has been applied. If not the particals will evaporate leaving you with small passages underneath the headgasket.
Will this be devistational? Probably not, but why run the risk. Do it right. Before learning about the properties of these sealant sprays I had incorrectly applied the sealant a few times with poor results.
good luck
Old Aug 13, 2004 | 08:02 PM
Turbo E's Avatar
ugh...i need a 1/2" drive 14mm socket. i only have 3/8" drive....
damn thos studs are tight
Old Aug 13, 2004 | 11:36 PM
Turbo E's Avatar
12:35 am just finished putting the head on. still need to drain the coolant and oil/ refill.
only 6 hours so far. do the rest tomorrow AM. ugh....
Old Aug 14, 2004 | 05:22 AM
CivicHall93's Avatar
I think that is the same cooper spray that you use on the back of your brake pads. At least I think so.
Old Aug 14, 2004 | 06:59 AM
vtec69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">12:35 am just finished putting the head on. still need to drain the coolant and oil/ refill.
only 6 hours so far. do the rest tomorrow AM. ugh....</TD></TR></TABLE>
good luck let us know how it turns out
Old Aug 14, 2004 | 09:14 AM
Turbo E's Avatar
Default Re: Head gasket help? (CivicHall93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicHall93 &raquo;</TD></TR><TR><TD CLASS="quote">I think that is the same cooper spray that you use on the back of your brake pads. At least I think so.</TD></TR></TABLE>
nah. you're thinking of anti-seize, or anti-squeel.
the spray is a metal based adhesive
Old Aug 14, 2004 | 10:55 AM
VTgringo's Avatar
Default Re: Head gasket help? (Turbo E 604)
damn........i post up the most factually sound information in this topic and no response........ungrateful h-t members.
ahh, i'm just grouchy. pay no attention to me
Old Aug 14, 2004 | 01:11 PM
Turbo E's Avatar
Default Re: (vtec69)
ok Im finished
i had the exhaust cam jump one tooth so the car ran like poop so i redid that and everything is gravy now
lessee...6:30pm to 12:30am yesterday then 10:30 AM to 2:00 pm today...hmmmm..10 hours...
thanks for all the help guys. I'll post pics later or something. i need some sleep now....
now lets see if i can keep it from blowing again this decade.
Old Aug 14, 2004 | 03:01 PM
wisjdmhonda's Avatar
i never used copper spray and i have had 0 problems
