ITR fuel pump
Old Nov 29, 2001 | 07:01 AM
Project X's Avatar
Default ITR fuel pump
Will the ITR fuel pump be good enough for 200 whp N/A application?
Old Nov 29, 2001 | 07:08 AM
rtype11's Avatar
Default Re: ITR fuel pump (Project X)
shuld not be a problem, just check that fuel pressure stays good at peak torque and does not drop. peak torque is the point where your car consumes the most amount of fuel.
Old Nov 29, 2001 | 07:56 AM
Project X's Avatar
Default Re: ITR fuel pump (rtype11)
What about the LS fuel pump?
Old Dec 8, 2001 | 05:37 PM
Project X's Avatar
Anyone?
Old Dec 8, 2001 | 05:39 PM
chri5's Avatar
i believe that all the pumps for the tegs are the same...
Old Dec 8, 2001 | 05:40 PM
Tomakit's Avatar
Default Re: ITR fuel pump (Strng1dah)
all teg fuel pumps are indeed the same.
Tom
Old Dec 8, 2001 | 09:48 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: ITR fuel pump (Tomakit)
If you want a Walboro higher flow pump try here: http://www.autoperformanceengineering.com/
They have a 255lph Walboro for about $97 or something and a high pressure 255lph pump for $107!
Old Dec 8, 2001 | 09:54 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: ITR fuel pump (Gee3)
LS uses a Civic fuel pump, GSR and ITR uses a bigger pump.
Old Dec 9, 2001 | 01:57 PM
Project X's Avatar
Default Re: ITR fuel pump (Mista Bone)
Hmm...2 people say the pumps are the same and 1 says it's not.
Anyone else know?
Old Dec 9, 2001 | 09:05 PM
Mista Bone's Avatar
D Tranny Guru
Look info up in helms. Info from person said there were 2 sets of specs. One for LS, other for GSR/ITR
Old Dec 9, 2001 | 10:01 PM
Project X's Avatar
Great. Thanks. I'll check the Helms manual.
lazywop
May 22, 2006 06:10 PM
wizzards581
Mar 22, 2004 04:09 PM
hsilva
Sep 3, 2002 04:21 PM
Charlie Moua
Jul 11, 2002 12:28 AM
