My Boosted Ej1
Old Aug 5, 2004 | 09:29 PM
P_t0wn's Avatar
Default My Boosted Ej1
Engine
D16z6 + Eagle Rods + SRP 9.1:1 Pistons + hondata + ACT XTSS + RSR + Apexi BB Turbo kit + JRC intercooler + misc crap
Ext
OEM si wheel + Tsunami t1 lip + VIS Hood + Tokico Spring / Shock kit ~1.5in drop
Int
USDM ITR seats + Infinity Components + Infinity 10in Sub + Greddy Boost + Defi A/F + autometer Oil Pressure
Feel free to put in your thoughts
Thanks
Old Aug 5, 2004 | 09:30 PM
Hatch It's Avatar
Default Re: My Boosted Ej1 (P_t0wn)
Post pics of this beast powerplant......
Nice though, how did you do the tail lights?
BUMP
Old Aug 5, 2004 | 09:33 PM
P_t0wn's Avatar
Default Re: My Boosted Ej1 (Cons94)
Ill get on the engine pictures in just a sec. The tail lights are very easy to do.
Take out both Tail lights, clean them, Get some Window Tint Spray or Night Shades i think is the brand, Cover the part you dont want tinted with tape, spray on a coat every 30-45 mins. I think i did 4 coats the first time around, I had to respray because it started to fade
plusONE jboy's Avatar
gotta love boost.
MiKeAhOwSkI's Avatar
Clean coupe man! Lovin the wheels and, even more, your turbo setup!
How far do you plan to push your setup? I'm curious because I'll have about the same thing.
Once again, I'm lovin the car overall
for SOHC power!!!
Old Aug 5, 2004 | 09:35 PM
P_t0wn's Avatar
Old Aug 5, 2004 | 09:37 PM
confusedJDMvwGTI's Avatar
Honda-Tech Counsellor
I like it better with no lip.
P_t0wn's Avatar
Default Re: My Boosted Ej1 (MiKeAhOwSkI)
Like I said I'm running 12 lbs right now. As of how i stand right now, I'm very happy with how the car pulls, 1st - 2nd is crazy. The engine the way its built right now + that its being tuned with hondata could boost well over a bar into the 16lb range. I'd like to try that, but i dont want to throw more cash into the money pit
Old Aug 5, 2004 | 09:38 PM
Trak_Day's Avatar
New User
Best body style Civic ever to come out! Nice ride man. I cant wait to get my boosted EJ1 on the road when it is all done!
Old Aug 5, 2004 | 09:40 PM
P_t0wn's Avatar
Default Re: (Trak_Day)
Make sure you check out TurboD16.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_t0wn &raquo;</TD></TR><TR><TD CLASS="quote">Like I said I'm running 12 lbs right now. As of how i stand right now, I'm very happy with how the car pulls, 1st - 2nd is crazy. The engine the way its built right now + that its being tuned with hondata could boost well over a bar into the 16lb range. I'd like to try that, but i dont want to throw more cash into the money pit
Sounds great man
I'd be itchin' to turn that baby up though
Old Aug 5, 2004 | 09:52 PM
Trak_Day's Avatar
New User
Default Re: (P_t0wn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_t0wn &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you check out TurboD16.com
Yeah, but i have a bored b18c1 84 mm. Although i love all honda sites with good info so i will check it out!
Old Aug 5, 2004 | 09:55 PM
P_t0wn's Avatar
Are you running the Apexi Kit Also? its going to take around 18-20 lbs to get 300whp outta that
Old Aug 5, 2004 | 10:14 PM
eJone powereD's Avatar
looking good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_t0wn &raquo;</TD></TR><TR><TD CLASS="quote">Are you running the Apexi Kit Also? its going to take around 18-20 lbs to get 300whp outta that
Nope, using my pieced together kit. Just need a larger turbo (have t3 .42/48 now) and bigger injectors+fuel pump and Map sensor to get to 300. Going to run 10 psi until then.
Old Aug 5, 2004 | 10:37 PM
P_t0wn's Avatar
Default Re: (DV)
Huh?
Old Aug 5, 2004 | 10:38 PM
mrdanglez's Avatar
clean boosted d16
Old Aug 5, 2004 | 10:44 PM
lunchboxEF91's Avatar
bump for sleeperz
Old Aug 6, 2004 | 08:49 AM
P_t0wn's Avatar
Default Re: (lunchboxEF91)
i wouldnt call it a true sleeper but thanks
Old Aug 6, 2004 | 09:39 AM
unknown0001's Avatar
Tail lights
Lip
motor
Old Aug 6, 2004 | 09:45 AM
Ya@inlinePRO's Avatar
looks good except for that lip!
and its pretty damn high off the ground
but nice clean setup
Old Aug 6, 2004 | 09:48 AM
Charlie Moua's Avatar
Default Re: (kwik2nec)
awesome to see more apexi turbo kit users!
check out peiku who just ran a 13.06 stock d16z6 9psi
how much power did you make on 12psi?
Old Aug 6, 2004 | 01:34 PM
P_t0wn's Avatar
Default Re: (Charlie Moua)
i hve not gone to a dyno but its over 200
Old Aug 6, 2004 | 01:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_t0wn &raquo;</TD></TR><TR><TD CLASS="quote">i hve not gone to a dyno but its over 200</TD></TR></TABLE>
yeah it better be over 200whp.
peiku made 210whp on about 9psi.
Old Aug 6, 2004 | 01:37 PM
P_t0wn's Avatar
outta the apexi kit?!??!
