Choosing a header
Old Aug 5, 2004 | 05:40 PM
KevHa's Avatar
Default Choosing a header
Stock exhaust manifold on my '96 Civic EX cracked and I've to decided to upgrade as a result. Couple of quick questions...
1) 4-2-1 or 4-1? Guess I'm looking more for low- and mid-range performance than high-end gains.
2) Ceramic or stainless? I'm not overly concerned with looks. How bad is the heat on the stainless?
3) 1-piece or 2-piece? Is there more to consider than weight? Is the difference significant?
I plan to replace the entire exhaust system soon also.
Thanks in advance for any help.
-Kev
Old Aug 5, 2004 | 05:46 PM
SwampThing's Avatar
Default Re: Choosing a header (KevHa)
4-2-1 low to mid, 4-1 higher end.
ceramic helps with the heat.
i personally like 1 piece less to deal with especially stripping screws and crap like that and eliminates one source for an exhaust leak.
Grip's Avatar
4-2-1 makes good mid range power and also some high range power as well..id recommend dc sports for the price and amount of power you make its the best bet for your application
ceramic will be cheaper and under hood temps will be slightly lower...stainless looks good runs hotter is more expensive and flows a little better(from what ive read)..id recommend ceramic for your application since you want somthing cheap that makes good power..the ceramic will offer all of that and its lighter then stainless too
id go with 1 piece for the weight issue..why have 2 iece when you can have 1 piece? im not 1200% sure but i dont think a 2 piece header has anything on a 1 piece at all..id recommend the dc sports 1 piece ceramic 4-2-1 header for your application its a direct swap..no modifications will be needed at all
Old Aug 5, 2004 | 05:47 PM
thrty8street's Avatar
imo if you just want to replace the stock header, just get watever is cheapest. 4-2-1 is usualy for mid range power and 4-1 for top end.
I got an ebay header that is 4-2-1 and ceramic coated.
Old Aug 5, 2004 | 05:53 PM
null.'s Avatar
Default Re: Choosing a header (thrty8street)
BISI!!!
http://www.exospeed.com
thats if money isn't an issue!
Old Aug 5, 2004 | 05:57 PM
Soccerking3000's Avatar
Default Re: Choosing a header (egb18turbo)
and if you want ot keep your a/c and p/s if you have it of course would be get the prospeed header, it is a replica of the bisimoto header and allows a/c and p/s
Old Aug 5, 2004 | 06:00 PM
null.'s Avatar
Default Re: Choosing a header (Soccerking3000)
ANR is another version also
Old Aug 5, 2004 | 06:39 PM
fishnfst's Avatar
Bang for the buck the weapon-r header that just came out. It's looks like a hytech knockoff just unbaffled..
Old Aug 5, 2004 | 07:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egb18turbo &raquo;</TD></TR><TR><TD CLASS="quote">ANR is another version also</TD></TR></TABLE>
unfortunetly the an-r doesn let you keep any of the accesories
Old Aug 5, 2004 | 07:10 PM
ebrakeracin4's Avatar
ive had a few dif. engines and I always use the 4-2-1 header.
Old Aug 5, 2004 | 07:17 PM
photec2's Avatar
Default Re: Choosing a header (ebrakeracin4)
cracked header you say i say turbo mani and boost it
Old Aug 6, 2004 | 06:13 AM
PahLok's Avatar
Default Re: Choosing a header (photec2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">4-2-1 makes good mid range power and also some high range power as well..id recommend dc sports for the price and amount of power you make its the best bet for your application
id go with 1 piece for the weight issue..why have 2 iece when you can have 1 piece? im not 1200% sure but i dont think a 2 piece header has anything on a 1 piece at all..id recommend the dc sports 1 piece ceramic 4-2-1 header for your application its a direct swap..no modifications will be needed at all </TD></TR></TABLE>
My friend runs a 4-2-1 DC sports stainless and it does the job very well, specialy when VTEC starts! I would go for the ceramic also.
Old Aug 6, 2004 | 06:42 AM
Sijray21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KevHa &raquo;</TD></TR><TR><TD CLASS="quote">Stock exhaust manifold on my '96 Civic EX cracked and I've to decided to upgrade as a result. Couple of quick questions...
-Kev</TD></TR></TABLE>
1) same as everyone else, 4-2-1 mid/low gains; 4-1 more high end gains
2) SS is less prone to rust out/crack and bling's nicely , ceramic's better for heat loss, but if you heatwrap a SS should do nicely to prevent too much heat
3) Just a matter of installation, 2 piece is easier to install (slightly heavier, not my much though)
i'd recommend a 4-2-1 one piece Ceramic
Old Aug 6, 2004 | 06:52 AM
BauleyCivic's Avatar
Risky Business
Default Re: Choosing a header (Sijray21)
Actually 4-1 gives more power than 4-2-1 over the entire powerband, ask spade.
I prefer 4-2-1 because of the fitment.
Old Aug 6, 2004 | 06:55 AM
ITRpwrdEG's Avatar
Landspeed Racing has the best production SOHC Vtec header that made around 8whp if I remember correct. It was some crazy number coming from that little motor. You barely even see that with a B-series header on a bone stock motor.
to LandSpeed
cost is around $375 maybe, but well worth it if you want every bit of horsepower. Plus, the 4-2-1 design gains even more low end than the 4-1, even though the 4-1 still gains down low.
Old Aug 6, 2004 | 08:52 AM
kommon_sense's Avatar
Default Re: Choosing a header (ITRpwrdEG)
http://www.hadamotorsport.com/....html
Old Aug 6, 2004 | 09:57 AM
BrianDelSol's Avatar
Default Re: Choosing a header (kommon_sense)
the only reason to really get a two piece is so you can get at your oil pan easy if you race alot, then you dont need to unbolt the whole thing
Old Aug 6, 2004 | 10:10 AM
_Spugen_'s Avatar
Default Re: Choosing a header (BrianDelSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street &raquo;</TD></TR><TR><TD CLASS="quote">
Whale *****...
Old Aug 6, 2004 | 10:13 AM
Cam79's Avatar
I rock the Apex GT SS 4-2-1, that ****** gets hot!......shes alittle pricy too.
Im happy with it though.
: Pointless post.....oh well ,we all have those once and awhile. :
Old Aug 6, 2004 | 10:26 AM
newbiehonda_05's Avatar
Default Re: Choosing a header (C00SI)
ive heard that the apex is a real quality peice(PRICE!) that shows great gains through the mid to high, but since you are the one buying them its up to what kinda money you have and personal preferance
Old Aug 6, 2004 | 12:38 PM
KevHa's Avatar
This link is AWESOME!! The most complete review of headers around.
Thanks!
-kev
Old Aug 6, 2004 | 07:59 PM
simplypinoyy's Avatar
Heres my DC Sport Header the 4-2-1 One piece. I like this one because I like the mid range power that i gained that helps me get into my vtec range quicker and I feel like I gained some power at higher rpms but that mite just be me.
Old Aug 6, 2004 | 08:17 PM
jerbear!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by photec2 &raquo;</TD></TR><TR><TD CLASS="quote">cracked header you say i say turbo mani and boost it</TD></TR></TABLE>
Old Aug 6, 2004 | 08:30 PM
chronodyne28's Avatar
Default Re: Choosing a header (SpugenEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpugenEG &raquo;</TD></TR><TR><TD CLASS="quote">
Whale *****... </TD></TR></TABLE>
Damn I wanted to be the one to point it out.
Old Aug 14, 2004 | 02:02 AM
PahLok's Avatar
Default Re: Choosing a header (chronodyne28)
Landspeed Racing has the best production SOHC Vtec header that made around 8whp if I remember correct. It was some crazy number coming from that little motor. You barely even see that with a B-series header on a bone stock motor</TD></TR></TABLE>
Mine´s a B16A2!
chode2002
Honda Civic (2001 - 2005)
May 10, 2008 09:59 AM
matto2413
Mar 6, 2005 08:46 PM
Fidelio25
Jul 27, 2004 10:15 AM
Shadow Templar
Jan 23, 2004 09:51 PM
Red-EJ
May 22, 2002 11:34 PM
