Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Different tires front and back
Old Aug 5, 2004 | 04:53 PM
Ki11erB's Avatar
Default Different tires front and back
I am currently using Advan Neovas all round. If I use Azenis Sport for the front and Advan Neovas at the rear, would my car handle better on the turn-ins? I'm currently using Zeal B6 coilovers (harder at the back and softer in front). How would this set up (different tires) affect the handling? Car seems to understeer in tight turns. Someone had recommended that I swap the springs front to back but I didn't wanna do that yet as it would be too bumpy for the streets. So I'm looking into tires now. Comments?
Old Aug 5, 2004 | 04:56 PM
chad's Avatar
Moderator
Default Re: Different tires front and back (Ki11erB)
suspension is the proper way to tune the car....not by tires....you are just hiding a problem if you are doing it with tires...
Old Aug 5, 2004 | 05:12 PM
.RJ's Avatar
.RJ
Default Re: Different tires front and back (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">you are just hiding a problem if you are doing it with tires...</TD></TR></TABLE>
Sometimes its the only tool you have, if restricted by r00lz.
Old Aug 5, 2004 | 05:14 PM
Sean O'Gorman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">suspension is the proper way to tune the car....not by tires....you are just hiding a problem if you are doing it with tires...</TD></TR></TABLE>
To add to what chad said, running different tires F and R may change the balance to feel more favorable, but would not result in the optimal grip that would come from having Azenis at all four corners and adjusting the suspension to find the desired balance.
Old Aug 5, 2004 | 06:01 PM
slammed_93_hatch's Avatar
Default Re: Different tires front and back (Sean O'Gorman)
whose to say that azenis have more grip then neova's ????
Old Aug 5, 2004 | 08:16 PM
Solracer's Avatar
Default Re: Different tires front and back (slammed_93_hatch)
When I was autocrossing in the stock class I ran differnt size tried font at rear, and hte car felt real good like that. I used to Run 215/50/14 in the front and 195/60/14 in the rear on my stock rims and the car rotated well. I would not run differnt tires front and rear, I did ths when my R1's wore out on the front and the car did not feel as good until I put Kuhmo's all around.
Old Aug 5, 2004 | 08:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">whose to say that azenis have more grip then neova's ????</TD></TR></TABLE>
I have no idea what a Neova is but I'm assuming since you see it nowhere in STS competition its not as grippy.
Old Aug 5, 2004 | 08:45 PM
Johnny Mac's Avatar
huh? There is no reason why you can't use different size tires to tune a chassis. And there isn't any rule that says you have to use the chassis to do all of the tuning. I have seen very successful setups with 225's in the front and 205's in the rear on CRX's. Can you force the chassis to give the same balance, sure. Problem is it may involve a spring change or a anti-rollbar change (if of course you have an adjustable anti-rollbar).
Old Aug 5, 2004 | 09:20 PM
Ki11erB's Avatar
Default Re: Different tires front and back (Johnny Mac)
Thanks guys on your comments. I've been using neova's in the last few auto-x's. Haven't been doing much rotation of switching front to back. Front tires are now 50% thread, rear 70% thread. I feel the fronts are not as grippy compared to when i first had them installed. The launching has more wheelspin now compared to previous. This made me thnk of changing to new azenis sport. At this point i don't want to swap the rear tires to the front, as i know the front tires are not that good anyway.
Old Aug 5, 2004 | 09:25 PM
Ki11erB's Avatar
slammed_93_hatch,
It was quite apparent to me that the azenis sport has more grip than the neova ad07's. I've followed different cars with these 2 tires on them, and my bonnet is prove to that.
Old Aug 6, 2004 | 01:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean O’Gorman &raquo;</TD></TR><TR><TD CLASS="quote">
I have no idea what a Neova is but I'm assuming since you see it nowhere in STS competition its not as grippy.</TD></TR></TABLE>
thats probably cause its not a US tire. and not DOT legal.
i have some that came on my ITR wheels when i upgraded my brakes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ki11erB &raquo;</TD></TR><TR><TD CLASS="quote">slammed_93_hatch,
It was quite apparent to me that the azenis sport has more grip than the neova ad07's. I've followed different cars with these 2 tires on them, and my bonnet is prove to that.</TD></TR></TABLE>
interesting, with mine i was doing just fine and they griped great.
i don't think mine are ad07's though i haven't noticed that on the tire
Old Aug 6, 2004 | 01:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">thats probably cause its not a US tire. and not DOT legal.</TD></TR></TABLE>
Then why would anyone want to autocross with it? It would just push you into the Prepared or Modified classes, wouldn't it?
Old Aug 6, 2004 | 02:15 PM
Then why would anyone want to autocross with it? It would just push you into the Prepared or Modified classes, wouldn't it?</TD></TR></TABLE>
good question, i have never ran or will never run an auto-X race, so i have no clue. but this forum is for road racing and autocross, and i didn't see were this guy said he only autocrossed, if he does, woops.
Old Aug 6, 2004 | 02:19 PM
He said it here:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ki11erB &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys on your comments. I've been using neova's in the last few auto-x's.</TD></TR></TABLE>
So I assumed that was his main concern as far as handling was concerned.
Old Aug 6, 2004 | 02:23 PM
He said it here:
So I assumed that was his main concern as far as handling was concerned.</TD></TR></TABLE>
aaa well if he is arleady running them maybe he is already in one of those classes? or maybe no one has called him out on it yet.
as chad said, id deffently mess with your suspension, becuase i KNOW the neova's are great tires.
Old Aug 6, 2004 | 02:26 PM
RineRacing's Avatar
Running Azenis just in the front will give you some oversteer (or just less understeer depending on how much understeer you already have).
As Chad mentioned it is a band-aid fix. Some people like to solve their understeer problems with smaller tires in the back but I would rather reduce understeer with suspension changes then lowering the overall grip level of the car (rule permitting of course).
FA All Day
Honda Civic (2006 - 2015)
50
Dec 24, 2007 08:21 PM
.Kevin.
Dec 4, 2007 04:12 PM
Rahxephon
Feb 8, 2007 05:23 PM
JunIntegra
14
Mar 15, 2005 09:15 AM
BlckBeautyVTEC
Oct 20, 2004 12:57 PM
