Just recieved Dp, could this cause a loss of power???
Old Aug 5, 2004 | 04:41 PM
Rod.'s Avatar
Default Just recieved Dp, could this cause a loss of power???
I just recieved my 3" ac friendly dp. I had a flange I bought way back to fit my sc61. I notice my flange that I have is bigger opening than the flange that came on the DP...which you can see in the pic. I have a sc61 .63 ar would keeping it that small cause a loss of power? What would happen if it doesnt?? One more question I never got my bung welded up top by the flange for wideband. Is that need for tuning with hondata?? Thank you
Modified by redturbocivic at 5:59 PM 8/5/2004
Old Aug 5, 2004 | 06:15 PM
Rod.'s Avatar
Default Re: Just recieved Dp, could this cause a loss of power??? (redturbocivic)
is everyone going to look. I just need some simple help
Old Aug 5, 2004 | 06:25 PM
boosted_dc2's Avatar
it may cause a slight loss, but i wouldnt wory. as far as the 02, your stock one gets unscrewed and a wideband is put in its place. or at the dyno they have a separate one that goes in your tailpipe.
Landon
Old Aug 5, 2004 | 06:33 PM
beepy's Avatar
Default Re: Just recieved Dp, could this cause a loss of power??? (boosted_dc2)
You can only use the WB in place of the stock sensor if your WB controller has a narrowband emulator. Some do, some don't. In any case, only some dyno's use the "sniffer", others use a wideband. I would weld in another O2 sensor boss anyway, since you are having to do fabrication to complete the downpipe.
Old Aug 5, 2004 | 07:33 PM
boostismycrack's Avatar
E-thug
Default Re: Just recieved Dp, could this cause a loss of power??? (beepy)
I flared mine out to the side of the turbo's exducer.
boostedteg909
Apr 25, 2013 11:53 PM
covertperformance
Welding / Fabrication
Mar 25, 2009 05:56 PM
Westrock2000
11
Jul 11, 2007 08:56 PM
nerdsports
Jun 15, 2005 09:33 AM
drumking15
Feb 8, 2005 07:43 PM
