Removing a Crx steering wheel ?
pop off the H in the middle with a razor blade or somethin and their will be a 19mm nut to take off. after that the wheel comes off and u just need to undo some connectors
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX »</TD></TR><TR><TD CLASS="quote">pop off the H in the middle with a razor blade or somethin and their will be a 19mm nut to take off. after that the wheel comes off and u just need to undo some connectors</TD></TR></TABLE>
what he said.
what he said.
what i do is center it, then take out the key...then turn the wheel to the right so it locks into place...use a pencil and make a line on the cover so i know where it lines up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchaos »</TD></TR><TR><TD CLASS="quote">what hub are you using to make that fit?</TD></TR></TABLE>
you dont need a hub..it bolts right on ! a guy in camebridge named Rob , with a black crx on this site has one on his rex..he told me it bolts right on.
Modified by Rob. at 6:31 PM 8/5/2004
thats awesome....let my search begin
can toronto rob (thats you) confirm it when you pop it on?
as for install....pop off 'h', remove nut, straighten out wheels, carefully remove old wheel (dont turn at all), put on new wheel straight up, bolt it down
Modified by mrchaos at 2:48 AM 8/6/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchaos »</TD></TR><TR><TD CLASS="quote">did you ebay your wheel toronto rob?</TD></TR></TABLE>
no man..got it from someone on torontocivics.com....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchaos »</TD></TR><TR><TD CLASS="quote">yeah i saw you post there.....minty mint?</TD></TR></TABLE>
minty fresh mint.
minty fresh mint.
kantfadedisazn
Dec 23, 2005 08:40 PM
