Gas Mileage 88-91 Civics with Swaps b16a, b18c/5, b17, b18, ZC ....
Please post your gas mileage.
What car you have what swap and ECU.
How much is full tank in gallon on ur car and how much u get on a full tank.
thanks
thanks
i get pretty steady about 250 to a tank with a Lx sedan supercharged d16z6 drivin around the city.
I'd like to see what others are getting too.
88 CRX Si w/modified B16A, around 220 miles per tank assuming 12 Gal tank. With the gauge on E i put in 8 Gal and the pump stopped so there must have been another 4 gal in the tank. Car is on the rich side...not sure how far though.
27-28 mpg
88 crx si
b20vtec w/ys1
usdm p30
345cc jdm prelude injectors are not helping...
11.9 gal tank, roughly 300 miles per tank before I fill up
88 crx si
b20vtec w/ys1
usdm p30
sohc zc vtec with a pg7 ecu....roughly 220miles, less then 200 when i "rip-it"...
i am running rich with my dohc ecu for the sohc though..
33.1 MPG in my stock D16Y8....weird my tank is only like 9 gal tops.
Last night i filled up 7.8 gallons from a little above Empty and got 260 miles on that amount.
Vince
Vince
I get around 25-27 MPG on city driving on my Boosted B16 and around 30-32 MPG on the freeway.
The best gas mileage that I had ever had in my CRX was 36MPG, this is pure Highway. (Long ago when I had the FMU setup)
Remember if your Vtec and boost does not kick in your in the clear. Once Vtec hits your car is drinking gas but with both combined then the engine is just guzzling it down like it's all good.
1991 B18A (stock)
PR4 ECU (un-chipped)
1991 CRX Si chassis (suspension mods)
and I can get 290 miles consistently and only have to put in about 9 gallons, so about 32-33 mpg. I drive HWY and city for my commutes.
W<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 »</TD></TR><TR><TD CLASS="quote">IC I thought hondas gave better gas mileage
So 30mpg isnt that great of gas miliage? What are you smoking? The best I have gotten with my B20 and PR4 ECU is 29.7mpg around town. I could of babied it a bit more and gotten 30, but whats the fun in that? hahah Fuel pressure was is at 37psi. Tires at 33psi. 36psi on a hot summer day.
Blaze
</TD></TR></TABLE>So 30mpg isnt that great of gas miliage? What are you smoking? The best I have gotten with my B20 and PR4 ECU is 29.7mpg around town. I could of babied it a bit more and gotten 30, but whats the fun in that? hahah Fuel pressure was is at 37psi. Tires at 33psi. 36psi on a hot summer day.
Blaze
I thought hondas gave better gas mileage </TD></TR></TABLE>
if u wanted better gas mileage then stay stock no mods, but then ask UR self this question:
Why you even cinsidering a swap then???
just a bit to think about
and my build Hybrid 2.1 liter
gets me 175 miles to tha tank, whats the purpose of having VTEC if u ain't going to use it???
I went to Niagara a month ago in my D16Z6 DX tranny beater and I got 42.5mpg. A couple of weeks later my fuel pump went out. So I really don't know if that was typical or if it was allready not putting out enough fuel. I will let you know the number soon as I empty a tank on my new walbro pump.
91 CRX Si
DOHC ZC
$15 to fill it with 91 octane in Cali which will last me almost 2 weeks and I drive alot.
Intake/Header/Wires
Friends with stock GSRs envy my gas mileage. - Darrell
DOHC ZC
Intake/Header/Wires
91 CRX Si
JDM B18c
"AIR" CF intake manifold
Stock header to 3" Kteller exhaust.
Stock JDM p72 ECU (for now)
I get about 30-31MPG
I get alot of hwy miles+LA traffic.....
Most of the time I drive like a lil bitch.... but atleast a couple times a day I let her rip when the conditions suit it (on ramps and what not).
JDM B18c
I got about 240MPH full tank Shell.
$20.00 about 8 Gallon
very bad. I go around 80 RPM is around 4500 the faster I go in 5th gear the higher rpm
bad gasmileage
bad gasmileage
