Will my ITR pass smog w/ these mods?
Old Aug 5, 2004 | 12:51 PM
ITR#465's Avatar
Default Will my ITR pass smog w/ these mods?
I have a 00 ITR with AEM intake, DC header, Spoon exhaust, Spoon clutch, Spoon flywheel, Spoon cams, Spoon cam gear. do u guys think will it pass smog with the stock p73 ecu?
Old Aug 5, 2004 | 12:53 PM
fuck honda-tech's Avatar
Default Re: Will my ITR pass smog w/ these mods? (RedLineDC2)
just go to a smog shop that only makes u pay if u pass.. that would be a good indicator.
Old Aug 5, 2004 | 01:01 PM
atc5's Avatar
you need to make sure the carb legal parts are for your year ITR or after.
You cannot have an 1998 carb approved intake on a 2000 car although most places will just see the carb sticker and let it go w/out looking it up.
give it a shot and see where your emissions come up....nobody can tell you if you will pass or not until you actually get tested.
Old Aug 5, 2004 | 01:11 PM
MugenH22AccordGirl's Avatar
I'm going with no.
Old Aug 5, 2004 | 01:17 PM
obd2gsr's Avatar
did you adjust those cam gears?
i highly doubt it.
Old Aug 5, 2004 | 02:15 PM
98itR484's Avatar
Default Re: Will my ITR pass smog w/ these mods? (obd2gsr)
In CA chances are NO you will not pass, i myself am in CA.
Where ever you decide to go, ask them to do a pre smog test...they will hook up the car run the machine, and tell you if it will pass or not, without sending info to the govern, usually it is around $20.
But with the exhaust/header if you go to a place that does work "by the book" you will automatically fail the visual.
Old Aug 5, 2004 | 02:38 PM
norice's Avatar
Default Re: Will my ITR pass smog w/ these mods? (98itR484)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itR484 &raquo;</TD></TR><TR><TD CLASS="quote">
But with the exhaust/header if you go to a place that does work "by the book" you will automatically fail the visual. </TD></TR></TABLE>
Not strictly true. CARB says nothing about exhausts. The header will pass if it has a CARB# on it. The Comptech header, for example, is CARB legal.
If your valve cover is cut for the cam gears, I doubt you will pass visual.
I doubt the cams will pass the sniffer test no matter what you do.
Old Aug 5, 2004 | 05:26 PM
98itR484's Avatar
Default Re: Will my ITR pass smog w/ these mods? (norice)
My mistake i read it as a Spoon Header and Exhaust, did not see the DC header
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norice &raquo;</TD></TR><TR><TD CLASS="quote">
.</TD></TR></TABLE>
If it is a JDM DC then he got a problem
Old Aug 5, 2004 | 05:43 PM
esponet's Avatar
if the gears are exposed, no you will not pass visual.
btw i know a person that passed with skunk type 2 cams, but he had to use 2 cats one after the other. the tech looked the other way for visual. he just cared about the sniffer test
Old Aug 5, 2004 | 06:28 PM
Splat's Avatar
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norice &raquo;</TD></TR><TR><TD CLASS="quote">I doubt the cams will pass the sniffer test no matter what you do.</TD></TR></TABLE>
How strict is the CA sniffer?
&lt;-- Passed NC emissions with Toda B's
Old Aug 5, 2004 | 10:07 PM
ITR#465's Avatar
no the cams are not been adjust. how can it hook up 2 cats?
Old Aug 5, 2004 | 10:09 PM
R4ND0M's Avatar
Default Re: (RedLineDC2)
Just wait until you have 1/4 tank left, and pour in some octane booster then get tested. It should help..
Old Aug 5, 2004 | 10:14 PM
ITR#465's Avatar
Default Re: (Rand0m)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rand0m &raquo;</TD></TR><TR><TD CLASS="quote">Just wait until you have 1/4 tank left, and pour in some octane booster then get tested. It should help..</TD></TR></TABLE>
what does that octane booster do?
Old Aug 6, 2004 | 12:17 AM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLineDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
what does that octane booster do?</TD></TR></TABLE>
Almost nothing.
You won't pass legally in CA.
Old Aug 6, 2004 | 12:55 AM
Jj0o3eyY's Avatar
Default Re: (SoCal ITR)
you should actually try driving your car a little hard before the smog testing. for some reason its easier to pass smog after the car has been driven for awhile. my friend couldnt pass smog before with his b18cr and the mechanic told him to go drive his car around for awhile and push it a couple times and come back. and well when he came back he passed it, go figure. i know its weird but i guess it works..
Old Aug 6, 2004 | 12:58 AM
uNF$@#!'s Avatar
Default Re: (Jj0o3eyY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jj0o3eyY &raquo;</TD></TR><TR><TD CLASS="quote">you should actually try driving your car a little hard before the smog testing. for some reason its easier to pass smog after the car has been driven for awhile. my friend couldnt pass smog before with his b18cr and the mechanic told him to go drive his car around for awhile and push it a couple times and come back. and well when he came back he passed it, go figure. i know its weird but i guess it works.. </TD></TR></TABLE>
you mean your car operates more efficiently when its running at normal operation tempertures? wow. who would have ever thought.
Old Aug 6, 2004 | 03:44 PM
SoCal ITR's Avatar
the hotter the cat gets, the better it works.
Old Aug 7, 2004 | 01:39 AM
B-money's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal ITR &raquo;</TD></TR><TR><TD CLASS="quote">the hotter the cat gets, the better it works.</TD></TR></TABLE>
exactly, On my preveous GSR I had an apexi header with no carb extempt badge and an aem cold air intake and it passed smog. Don't know how though.
91(si)hatchey
Nov 15, 2010 04:39 PM
SarahVTEC
Jun 2, 2009 01:52 PM
PePpeRedDc5
May 4, 2005 08:01 PM
ITR#465
Jul 30, 2004 03:45 PM
bhcvc
Mar 28, 2002 01:18 PM
